Hello all, i have been trying to recreate an ir signal that is transmitting from a transponder for rc car laptimer use. The problem is, i cant get it to work. The workflow is this-the transponder in the rc car will send a signal to the decoder first in order to register a driver in an app. After that, it can race as usual.My problem is i cant recreate the signal that the transponder is transmitting in order to recreate it using my arduino/esp32. I have looked at the waveform using an oscilloscope and decoded it, but it still does not work. Keep in mind that im sending raw data. Included here is the waveform, coding used, csv and wfm files. Im a newbie in this and hope you guys can help me. Thanks!
Please post 2 things,
- Code
- Schematics
Hi, @afiqluqman11
Welcome to the forum.
Can you tell us the make and model of the transponder you are trying to replace with an Arduino?
How did you get signal that you posted?
Until you work out what is actually transmitted, such as an IR signal that is pulsed at 38kHz as a carrier and then digitally switched ON and OFF to transmit data, you can't really replicate it.
Tom....
Use micros() for timing the pulses.
Thanks for all the reply, the make and model of the transponder is from Lapmonitor, im trying to recreate it as my final year project in university. The image attached is what is transmitted by the said transponder, i attached the oscilloscpe probe on the +ve part of the transponder. The device is basically just an ir led attached to a circuit board. Do tell me if anything else is needed. Any feedback is greatly appreciated
Is the gap between the pulse trains fix or does it depend on feedback?
Thanks for the reply, in the system, the transponder doesnt just send pulses on a fixed timer, its a little bit smarter than that. The system has 2 devices, a transponder(tx) and decoder(rx). When i start a race, the transponder connects to a decoder and only after that the pairing/registration step does it begin transmitting regularly.
To answer your question:
- The gap between pulse train is not always fixed.
- It depends on system state, before registration, the transponder might wait or send less freuently. After registration, it seems to send pulse trains at a more consistent interval, containing its unique ID for lap detectin or driver tracking
Yes this is the transponder that i use,we can know if the pairing is successfull in the lapmonitor app. Each transponder has their own id or driver's id in rc car context, and when paired, it will show a number (45 for example). Regarding the protocol, it doesnt seem to be using any mainstream protocol. I have tested using NEC protocol and by using captured HEX to try and transmit it using ESP32, but no luck so far.
How does the TRANSPONDER know if the pairing has been successful, so it can begin to transmit regularly?
Tom....
In the case of the LapMonitor system,the transponder doesn’t actually wait for or detect pairing. Instead, it starts transmitting its unique ID in an IR pulse pattern immediately after it's powered on. It just keeps transmitting at regular intervals (e.g., every ~150ms), regardless of whether it's paired. The receiver (LapMonitor base station) is the one that does the pairing. When it detects a valid transponder ID, it saves or registers it for lap counting. So the transponder is essentially "blind" t never knows if pairing was successful or not. The pairing logic still happens on the decoder side, not the transponder.
In other words, the receiver simply learns the transmitter ID. The use of the term pairing is misleading in this case.
For help on this forum, please read and follow the directions in the "How to get the best out of this forum" post, linked at the head of every forum category.
It would be nice to see the actual signal timing and the method you are using to recreate the signal. The scope is showing an active low signal for the receiver and that is normally the case. At the transmitter that signal would be transmitted inverted. Also can you get your scope on the transmitter and read the carrier frequency?
The carrier frequency is on the third image i provided, atleast i think it is. As for the method, ive tried a few, from using HEX code, binary, to sending raw data. How i got the data is from a sniffer device using a receiver with arduino that translates the data to hex and raw data.
