Hello everyone. I'm a newb to the forums, but have a good amount of experience working with Arduinos. I am working with the YX5300 MP3 Player module and an Arduino Uno, and for the most part things are pretty good. After scouring around, I've been studying marco_c's excellently designed library.
However, my question is about some of the other example code that I've seen out there. It's tickling my brain and I can't seem to figure it out. I've seen various versions of this code in several places online, and none of them have the capturing unsolicited messages working. This means you can't query the MP3 player for volume, total tracks, status, etc...
#include <SoftwareSerial.h>
#define ARDUINO_RX 5 //should connect to TX of the Serial MP3 Player module
#define ARDUINO_TX 6 //connect to RX of the module
SoftwareSerial mp3(ARDUINO_RX, ARDUINO_TX);
static int8_t Send_buf[8] = {0}; // Buffer for Send commands. // BETTER LOCALLY
static uint8_t ansbuf[10] = {0}; // Buffer for the answers. // BETTER LOCALLY
String mp3Answer; // Answer from the MP3.
String sanswer(void);
String sbyte2hex(uint8_t b);
/************ Command byte **************************/
/* Various CMD defines...
/************ Opitons **************************/
mp3.begin(9600);
sendCommand(CMD_SEL_DEV, 0, DEV_TF);
char c = ' ';
// If there a char on Serial call sendMP3Command to sendCommand
if ( Serial.available() )
c = Serial.read();
sendMP3Command(c);
// Check for the answer.
if (mp3.available())
Serial.println(decodeMP3Answer());
delay(100);
void sendMP3Command(char c) {
switch (c) {
case '?':
case 'h':
Serial.println("HELP ");
Serial.println(" p = Play");
Serial.println(" P = Pause");
Serial.println(" > = Next");
Serial.println(" < = Previous");
Serial.println(" s = Stop Play");
Serial.println(" + = Volume UP");
Serial.println(" - = Volume DOWN");
Serial.println(" c = Query current file");
Serial.println(" q = Query status");
Serial.println(" v = Query volume");
Serial.println(" x = Query folder count");
Serial.println(" t = Query total file count");
Serial.println(" f = Play folder 1.");
Serial.println(" S = Sleep");
Serial.println(" W = Wake up");
Serial.println(" r = Reset");
case 'p':
Serial.println("Play ");
sendCommand(CMD_PLAY);
case 'P':
Serial.println("Pause");
sendCommand(CMD_PAUSE);
case '>':
Serial.println("Next");
sendCommand(CMD_NEXT_SONG);
sendCommand(CMD_PLAYING_N); // ask for the number of file is playing
case '<':
Serial.println("Previous");
sendCommand(CMD_PREV_SONG);
case 's':
Serial.println("Stop Play");
sendCommand(CMD_STOP_PLAY);
case '+':
Serial.println("Volume Up");
sendCommand(CMD_VOLUME_UP);
case '-':
Serial.println("Volume Down");
sendCommand(CMD_VOLUME_DOWN);
case 'c':
Serial.println("Query current file");
case 'q':
Serial.println("Query status");
sendCommand(CMD_QUERY_STATUS);
case 'v':
Serial.println("Query volume");
sendCommand(CMD_QUERY_VOLUME);
case 'x':
Serial.println("Query folder count");
sendCommand(CMD_QUERY_FLDR_COUNT);
case 't':
Serial.println("Query total file count");
sendCommand(CMD_QUERY_TOT_TRACKS);
case 'f':
Serial.println("Playing folder 1");
sendCommand(CMD_FOLDER_CYCLE, 1, 0);
case 'S':
Serial.println("Sleep");
sendCommand(CMD_SLEEP_MODE);
case 'W':
Serial.println("Wake up");
sendCommand(CMD_WAKE_UP);
case 'r':
Serial.println("Reset");
sendCommand(CMD_RESET);
String decodeMP3Answer() {
String decodedMP3Answer = "";
decodedMP3Answer += sanswer();
switch (ansbuf[3]) {
case 0x3A:
decodedMP3Answer += " -> Memory card inserted.";
case 0x3D:
decodedMP3Answer += " -> Completed play num " + String(ansbuf[6], DEC);
case 0x40:
decodedMP3Answer += " -> Error";
case 0x41:
decodedMP3Answer += " -> Data recived correctly. ";
case 0x42:
decodedMP3Answer += " -> Status playing: " + String(ansbuf[6], DEC);
case 0x48:
decodedMP3Answer += " -> File count: " + String(ansbuf[6], DEC);
case 0x4C:
decodedMP3Answer += " -> Playing: " + String(ansbuf[6], DEC);
case 0x4E:
decodedMP3Answer += " -> Folder file count: " + String(ansbuf[6], DEC);
case 0x4F:
decodedMP3Answer += " -> Folder count: " + String(ansbuf[6], DEC);
return decodedMP3Answer;
void sendCommand(byte command){
sendCommand(command, 0, 0);
void sendCommand(byte command, byte dat1, byte dat2){
delay(20);
Send_buf[0] = 0x7E; //
Send_buf[1] = 0xFF; //
Send_buf[2] = 0x06; // Len
Send_buf[3] = command; //
Send_buf[4] = 0x01; // 0x00 NO, 0x01 feedback
Send_buf[5] = dat1; // datah
Send_buf[6] = dat2; // datal
Send_buf[7] = 0xEF; //
Serial.print("Sending: ");
for (uint8_t i = 0; i < 8; i++)
mp3.write(Send_buf[i]) ;
Serial.print(sbyte2hex(Send_buf[i]));
String shex;
shex = "0X";
if (b < 16) shex += "0";
shex += String(b, HEX);
shex += " ";
return shex;
int shex2int(char *s, int n){
int r = 0;
for (int i=0; i<n; i++){
if(s[i]>='0' && s[i]<='9'){
r *= 16;
r +=s[i]-'0';
}else if(s[i]>='A' && s[i]<='F'){
r *= 16;
r += (s[i] - 'A') + 10;
return r;
uint8_t i = 0;
String mp3answer = "";
// Get only 10 Bytes
while (mp3.available() && (i < 10))
uint8_t b = mp3.read();
ansbuf[i] = b;
i++;
mp3answer += sbyte2hex(b);
// if the answer format is correct.
if ((ansbuf[0] == 0x7E) && (ansbuf[9] == 0xEF))
return mp3answer;
return "???: " + mp3answer;
I've been wracking my brain trying to figure out why it isn't picking up unsolicited messages. I've studied the message flow article from here, but I guess I wanted to understand why these examples don't for my own sanity. I've tested the module against marco_c's library and I can see that it does handle unsolicited messages correctly. Whenever I try to send any commands requesting information from the above code, I simply get the 'ACK' response and never get the message with the requested data.
Thanks for the help!
