Thank you.
I was able to do some research and found a Sharp IR sensor which can go upto 550cm which is about 18 feet.
and use the code and everything works ok but to get the data logger add it to it is a challenge for me.
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
//#include <TinyWireM.h> // Enable this line if using Adafruit Trinket, Gemma, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment(); //end Adafruit requirements
const int sensorPin = 0; //analog pin 0
const int ledPin = 13; // the pin that the LED is attached to
// vars
int sensorCounter = 0; // counter for the number of button presses
int sensorState = 0; // current state of the sensor
// initialize the sensor pin and input
pinMode(sensorPin, INPUT);
// initialize the LED as an output
pinMode(ledPin, OUTPUT);
// initialize serial communication
// set the matrix
matrix.begin(0x70);
// read the sensor input pin:
sensorState = analogRead(sensorPin);
// if sensor is closer than than x distance
if (sensorState > 600 ) {
sensorCounter++;
Serial.println(sensorState);
Serial.print("number of counts: ");
Serial.println(sensorCounter);
// show output on the digital display
matrix.print(sensorCounter);
matrix.writeDisplay();
// slow down the output
// turns on the LED every ten counts
if (sensorCounter % 10 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
