Car Indicator
 int red1 = 10;
int yellow1 = 9;
int green1 = 8;
int button1 = 12;
int red2 = 6;
int green2 = 7;
int yellow2 = 5;
int button2 = 13;
int buttonState = 0;
  pinMode(red1, OUTPUT);
  pinMode(yellow1, OUTPUT);
  pinMode(green1, OUTPUT);
  pinMode(button1, INPUT);
  pinMode(button2, OUTPUT);
  pinMode(red2, OUTPUT);
  pinMode(green2, OUTPUT);
  pinMode(yellow2, OUTPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(button1);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(red1, HIGH);
    digitalWrite(yellow1, HIGH);
    digitalWrite(green1, HIGH);
  else {
    // turn LED off:
    digitalWrite(red1, LOW);
    digitalWrite(yellow1, LOW);
    digitalWrite(green1, LOW);
  if (buttonState = digitalRead(button1);
    // turn LED on:
    else {
      // turn LED off:
void changeLights() {
My error is expected " ')' before ';' token ". When i fix it, the error expected " primary-expression before ')' "token appears. Pls help.
I have fixed the mistake but i found another. I would really like help in fixing it
 int red1 = 10;
int yellow1 = 9;
int green1 = 8;
int button1 = 12;
int red2 = 6;
int green2 = 7;
int yellow2 = 5;
int button2 = 13;
int buttonState2 = 0;
  buttonState2 = digitalRead(button2);
  if (buttonState == HIGH); {
    // turn LED on:
  else {
    // turn LED off:
  if (buttonState2 = digitalRead(button2);
      if (buttonState2 == HIGH);
        // turn LED on:
        digitalWrite(red2, HIGH);
        digitalWrite(yellow2, HIGH);
        digitalWrite(green2, HIGH);
else {
// turn LED off:
digitalWrite(red2, LOW);
  digitalWrite(yellow2, LOW);
  digitalWrite(green2, LOW);
Check your brackets and drop the semicolon on line 43
Study the examples in the referance carefully;
https://www.arduino.cc/en/Reference/Else
Does your use of If then Else match ?
    if (buttonState2 = digitalRead(button2);  //missing a closing bracket and <<<<<<<<< see more comments below
That is a very unusual way to read the state of an input. I assume that you meant
because just one line of code later you have
        if (buttonState2 == HIGH);  //<<<<<<<<< see more comments below
If you want to combine the two and don’t need to put the state in a variable to be used elsewhere in the program you can use
        if (digitalRead(button2) == HIGH)
or even
if (digitalRead(button2))
MORE COMMENTS
Terminating an if with a semicolon effectively stops the test occurring because the only code executed should the test return true is the semicolon.
