Car Park with Arduino Uno
Hello everyone
I ask you for a little help with a school project that I am doing and I am using an Arduino Uno. The project is a car park for 8 spaces with a free indicator park and park complete with an inlet and an outlet (using servos) and if possible a 7-segment display (which indicate the number of vacancies in park). My idea was that if a car was to enter the park opened the barrier for 5 seconds and after that time the barrier closes and this car is added to the count and exit when a car is about to leave the barrier opens and closes after 5 seconds a car and is taken to the count. When the park is full, the red light comes on and as soon as a car leaves the red light turns off and turns on the green light.
Will can give me a little help?
Help with what? The electronics, the code or the idea? If this is to be a real carpark entry system and your barrier comes down after 5 seconds it will probably damage every car that enters and leaves! What you need to do is to detect when the car has left the area of the barrier [u]before[/u] you let the barrier come down.
The park is just like a model. And just need help with the program the Arduino.
When I'm going to upload the program to the Arduino it gives me some errors in variables. Will could give me a hand with the program?
Tuba121: When I'm going to upload the program to the Arduino it gives me some errors in variables. Will could give me a hand with the program?
Show us your code, use "#" to insert code. What error message?
The code is:
Parque_de_Estacionamento.ino (2.61 KB)
Well, I took the trouble to download your code, then put in my IDE andhit the compile button to get your error messages. Life would be easier if you did those things → http://arduino.cc/forum/index.php/topic,148850.0.html see the end of section 7.
Your problem is
const int One = 3 , 4;
and lines like that.
How can one constant (or variable for that matter) hold several values? It can not. From your program I can not guess what you meant by that.
if(COUNTER<1Car)is flagged as invalid suffix “Car” on integer constant
Your problem is that you can not combine a number “1” with “Car” like that. I can not guess if you meant 1+Car or a variable named “one_car”.
First make some little program that turns LED 1 on if you hit the “add car” and off when you hit the “subtract car”. I think that will help you understand some basic syntax of C. After that we can look into the flow of your program logic.
