bluejets:
Sounds to me you have other serious problems in the electrics somewhere.
....maybe like feedback from adding extra circuitry perhaps..???
On the original subject, run the arduino off a standard 4cell nimh pack and recharge that via a small regulator such as the usb charger type each time the engine runs.
Probably not such a good idea having engines starting without warning by automatic means unless limited access provisions are in place for safety reasons.
I have added a few things, a remote starter module, USB port power with key on, and a one-shot 2 min delay on relay to keep the heater blower fan off while the car starts and warms up. Also, I have disconnected power to the antenna in the winter so it doesn't freeze.
I agree that there are safety concerns, the neutral safety switch is bypassed for remote starting; I couldn't track down the right wire. The vehicle is always locked so I am not too worried about tampering. Do you think a short horn blast would be sufficient to bring attention to the vehicle seconds before starting?
To use the battery pack you suggested, it would maybe only need 12 to 24 hour capacity. Do you think it could handle that at -30C?
Great idea though, it would be nice to completely isolate the arduino power source. In the winter if the car battery dies it can be a hassle, being late for work or class.
Thanks for the suggestion.
rogerClark:
Which heater are you referring to, the fan motor that blows the air. That won't take a lot of current, and antenna motors don't take that much either.
The symptoms are of either and old and tired battery, or bad connections to the battery, either at the battery (very common) or at the GND where the -Ve of the battery is attached to the chassis metal of the car
Thanks, I checked the chassis to battery ground and it is very rusty and corroded. Will replace soon and sand off the rust.
