Car Turn Signal lever and Light to PC Arduino UNO
This is my first post so welcome. I come to you asking for help. I wanted to use the turn signal lever and wipers for my simulator. I have a lever from the Golf 6 switches working on resistance. I connected all the cables and checked with a multimetr. The question is how to write a sketch. I checked the changes under 5v voltage. I have 12 cables, 6 of which are connected after 5 volts. 5 is probably responsible in this case for analog outputs. One is dead and does not show any changes. Thank you for.
108-1619005438
Please post a diagram showing the details of the lever connections, according to what you measured.
I don't really see what your post has to do with, "Leds and Multiplexing", though...
Unfortunately, I do not have any djagram dzwigni, and I can not find. I will ask if it will be possible to connect it to the sketch from the 32 button box which is generally available on the Internet and whether it can be done on UNO or better Leonardo.
How did you determine what each wire is doing without making some type of diagram? Pencil and paper and a scan or a photograph of the paper works just fine.
I thought it was the original diagram of the lever, I don't have it. But what I have measured and how I see it will be sent in the morning when I am in the workshop.
Hi sorry for the delay. I'm probably not the best at drawing, but I drew tables and all the values I measured.
20220831-181845
