CardInfo.ini only detects card once
Hi. I have built my own MicroSD card PCB and I am trying to test it with an Arduino UNO running the CardInfo.ini example sketch for the SD library.
I find that if I physically remove the SD card from the holder, replace it, and then reset the UNO the card is detected correctly. However, if I reset the UNO again the card is not detected. I can do multiple resets and it never detects the card. If I remove and replace the SD card and then reset it detects it again (once).
My question is, should I be able to detect the card using the Cardinfo.ino sketch each time I reset the UNO? Or is it only supposed to detect once after inserting the card?
