Caricare un array da file .txt su SD
salve a tutti,
sto cercando di caricare un array di un indirizzo MAC prendendo i singoli byte da un file di testo salvato su SD
sto usando arduino con M5STACK (esp32) ed espnow
con questo codice
#include <M5Stack.h>
#include <esp_now.h>
#include <WiFi.h>
esp_now_peer_info_t slave;
//uint8_t remoteMac[] = {0x50, 0x02, 0x91, 0xA0, 0x63, 0xFD};
uint8_t remoteMac[6];// PROVA MAC ADDRESS DA SD
int arrayC = 0;
const uint8_t maxDataFrameSize = 200;
// must match the controller struct
struct __attribute__((packed)) DataStruct {
  int X;
  int Y;
  int Z;
DataStruct myData;
const esp_now_peer_info_t *peer = &slave;
uint8_t dataToSend[maxDataFrameSize];
unsigned long lastSentMillis;
unsigned long sendIntervalMillis = 10;
unsigned long sentMicros;
unsigned long ackMicros;
  M5.begin();
  M5.update();
  Serial.print("\r\n\r\n");
  WiFi.mode(WIFI_STA);
  Serial.println( WiFi.softAPmacAddress() );
  readMAC();
  WiFi.disconnect();
  if (esp_now_init() == ESP_OK)
    Serial.println("ESP NOW INIT!");
    Serial.println("ESP NOW INIT FAILED....");
  memcpy( &slave.peer_addr, &remoteMac, 6 );
  slave.channel = 1; // canale
  slave.encrypt = 0;
  if ( esp_now_add_peer(peer) == ESP_OK)
    Serial.println("Added Peer!");
  esp_now_register_send_cb(OnDataSent);
void readMAC() {
  File fh = SD.open("/MAC.txt");
  char netBuffer[15];
  if (!fh)
    Serial.println("SD open fail");
    return;
  int chPos = 0;
  while (fh.available())
    char ch = fh.read();
    if (ch == '\r') {
      chPos = 0;
      //          Serial.print("mac ");
      sscanf(netBuffer, "%2x:%2x:%2x:%2x:%2x:%2x", &remoteMac[0], &remoteMac[1], &remoteMac[2], &remoteMac[3], &remoteMac[4], &remoteMac[5]);
    else if (ch == '\n') {
      // do nothing
    else if (chPos < 14) {
      netBuffer[chPos] = ch;
      chPos++;
      netBuffer[chPos] = 0;
  fh.close();
  int x;
  Serial.print("\r\nmac ");
  for (x = 0; x < 6; x++) {
    Serial.print(remoteMac[x], HEX);
    if (x < 5) Serial.print(":");
con un file salvato su sd dal nome MAC.txt che contiene una sola riga come la seguente:
50:02:91:A0:63:FD
nel monitor seriale ho un output interessante ma imperfetto :
mac 50:2:91:A0:63:0
e master e slave di espnow non si collegano....
se inverto queste righe master e slave si collegano ma non sto leggendo il MAC address da sd..
//uint8_t remoteMac[6];// PROVA MAC ADDRESS DA SD
cosa sto sbagliando??
Stai leggendo solo 14 caratteri ma la stringa del mac compresiva dei ':' ha un totale di 17 caratteri (escluso \r e \n).
l'output seriale ora somiglia molto di piu al file!!!
mac 50:2:91:A0:63:FD
anche se mi manca all'appello quello 0 prima del 2...
ma il problena ora è che la scheda crasha con questo errore subito dopo avermi dato l'output seriale del mac address:
Backtrace: 0x4008cebc:0x3ffb1ea0 0x4008d0ed:0x3ffb1ec0 0x400e1398:0x3ffb1ee0 0x400d2c6a:0x3ffb1f00 0x400d3439:0x3ffb1f60 0x400dcec7:0x3ffb1fb0 0x400895d1:0x3ffb1fd0
forse ad espnow non piace questo metodo...
mumble mumble
Lo 0 manca perché la Serial.print() il valore 0x02 lo stampa come 2 e basta.
Per quanto riguarda l'errore, assicurati che l'array netBuffer sia grande abbastanza.
mettendo a 18 netbuffer funziona!!!!
grazie mille!!!!
