bronco9588:
Are your gear shift points going to be the same RPM? Most likely your optimal acceleration would not be the same RPM. Are you going to be down shifting with this setup? How does the pneumatic shifter work? Will the arduino be powerful enough to operate the pneumatic driver?I think this is a fun project. As always, you accept some risk with not using a COTS solution.
its for a 1/4 mill track car. so the shift is at the same rpm every time, no down shift.
i have a arduino running the pnumatic shift in a test setup now.
