'CASE' block doesn't need braces, or does it
Just having started coding in C I was unsure when to use {} and took the view that it couldn't be wrong to use them in excess to when writing using switch/case I used them also fro the 'case' block.
Having been told that this wasn't necessary I went back to my code and removed them from the case blocks. Result a whole string of compiler errors.
The following code has three almost identical case(9): blocks, two are commented out. Both the commented out blocks compile OK, one having {} delineators and the other the 'int incr' statement separate from the assignment of its value.
These are the compiler errors. What's going on?
Arduino: 1.6.4 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Build options changed, rebuilding all
sketch_may20c.ino: In function 'void loop()':
sketch_may20c:31: error: jump to case label [-fpermissive]
sketch_may20c:14: error: crosses initialization of 'int incr'
sketch_may20c:32: error: jump to case label [-fpermissive]
sketch_may20c:35: error: jump to case label [-fpermissive]
sketch_may20c:36: error: jump to case label [-fpermissive]
sketch_may20c:40: error: jump to case label [-fpermissive]
sketch_may20c:41: error: jump to case label [-fpermissive]
sketch_may20c:45: error: jump to case label [-fpermissive]
sketch_may20c:46: error: jump to case label [-fpermissive]
sketch_may20c:50: error: jump to case label [-fpermissive]
sketch_may20c:51: error: jump to case label [-fpermissive]
char message[10];
  switch (message[0]) {
    case '9':
      Serial.println(message);
      int incr  = atoi(message);
    case '9': {
     case '9':
       int incr;
    case 'S':
    case 's':
    case ('R'):
    case ('r'):
    case ('L'):
    case ('l'):
    case ('C'):
    case ('c'):
    case ('P'):
    case ('p'):
If you're going to declare multiple variables with the same name ("incr") in the same scope (the "switch" code block), then I'd recommend braces for the "case"s.
AWOL:
I only declare "INCR" once in the switch code, just in the case 9 block, and in the 3rd example using
        int incr;
doesn't seem to the case braces
But "incr" (C is case-sensitive) is in-scope in ALL the case blocks, but initialised only in one.
This is a potential source of bugs.
stackoverflow is a really useful resource.
Forgive the slowness of my old brain. Is the the 'scope' in this case only the 'switch' block or the main 'loop()'?. I initialised it in the case block it's used in and I don't use it anywhere else so I still don't see why declaring it on one line and initialising it on the other works (the 3rd example), but doing it on the same line doesn't, after all 'for(int i=0;.......)' is perfectly legal.
Any local variable is in scope from the point it is defined until the next closing brace.
Did you read the stackoverflow explanation?
I think the message is saying that you declare "incr" but by not taking the case label you are skipping the assignment.
So for example:
    case '9':
    case '8':
      incr = 8;
You get the error because incr never gets the initial value on case '8'.
Safer options:
    case '9':
That makes "incr" local scope. Or:
    case '9':
    case '8':
      // whatever;
Now "incr" exists inside every case label.
In your example, what is the point of the "incr" variable since you never use it?
The example was trimmed code so I could post it. The actual bit I use is
      case '9':    //numeric
        messptr = 0;
        int incr;
        if (incr != 0) {    // only numbers so move the prior selected servo
          if (servnum > 0) {
            moveservo(servnum, last[servnum] += incr);
          else {
            pstring = "No servo selected";
            Serial.println(pstring);
AWOL:
No, I've just tried putting 'stackoverflow' into the search block but nothing seems relevant. could you give me a link?
To save you writing stuff like
     case '-':
      case '+':
      case '0':
      case '1':
      case '2':
      case '3':
      case '4':
      case '5':
      case '6':
      case '7':
      case '8':
      case '9':
you can in some circumstances write
     case '-':
      case '+':
      case '0' ... '9':
, though it may not be portable.
I already gave you a link in reply #3
DavidI:
He gave you a link, you don't need to search for anything. Just click on it. Following his link I reached:
AWOL:
snip.....
     case '-':
case '+':
     case '0' ... '9':
Thanks for that, So just like pascal but pascal uses x..x not x...x (two dots not three)
Case Number of
 1..10   : WriteLn (’Small number’);
 11..100 : WriteLn (’Normal, medium number’);
 WriteLn (’HUGE number’);
end;
so when I typed case '0' .. '9': and got an error I assumed you couldn't do it in C, which seems to be the case from some googling I did. Now I'm really happy! but it still seems that C won't let you do
Case C of
 ’a’,’e’,’i’,’o’,’u’ : WriteLn (’vowel pressed’);
 ’y’ : WriteLn (’This one depends on the language’);
  WriteLn (’Consonant pressed’);
end;
or am I wrong again?
AWOL:
Which I missed, sorry! going to read it now
Ellipsis is always written with three dots, but Wirth is Swiss, so what does he know? :wink:
Sorry, I gave up on Pascal a long time ago.
Just read it. Now I understand. The compiler is clever enough to pick up the problem and not let me do it even though I use the variable only in that block. However, sanity check, splitting the declaration and initialisation into two separate lines
      case'1'...'9':    //numeric
        int incr;
would appear to still suffer from the same problem but the compiler hasn't picked it up. So I should add the braces to limit the scope to the single 'case' right.
There is no problem any more. No initialization has been skipped. A statement has not been executed, which is different from a variable not being initialized.
If you don't add the braces then incr exists till the end of the switch statement, eg.
  case'1'...'8':    //numeric
    int incr;
  case '9':
    int incr;
Gives:
sketch_may20d.ino: In function ‘void loop()’:
sketch_may20d:18: error: redeclaration of ‘int incr’
sketch_may20d:14: error: ‘int incr’ previously declared here
