Hi I'm fairly new to Arduino, I'm trying to make a night light with different modes but when cycling through the modes by pressing in the rotary controller mode 3 won't change to mode 4 which is off, im at a loss for why..?
any help would be very much appreciated.
#include <Encoder.h>
const int NUM_LEDS = 60; // number of leds in strip
const int LED_PIN = 5; // pin for led strip
const int BRIGHTNESS = 255; // brightness of all leds
const int WHEEL_SIZE = 256; // how many entries in the color wheel
const boolean MOVE_LIGHT = false; // move one light around or keep all lights on
const int ENCODER_PIN_1 = 2;
const int ENCODER_PIN_2 = 3;
const int ENCODER_BUTTON = 4;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_RGB + NEO_KHZ800);
Encoder encoder(ENCODER_PIN_1, ENCODER_PIN_2);
int mode = 0;
long lastPush = 0;
int autoPosition = 0;
void initializeToBlack() {
for (int i =0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, 0);
uint32_t white = strip.Color(255, 255, 255);
pinMode(ENCODER_BUTTON, INPUT);
digitalWrite(ENCODER_BUTTON, HIGH); //turn pullup resistor on
strip.begin();
initializeToBlack();
strip.show();
long normalize(long value, long radix) {
long rval = value % radix;
if (rval < 0) return radix + rval;
else return rval;
int button= digitalRead(ENCODER_BUTTON);
if (button == 0) {
if ((millis() - lastPush) > 250) {
lastPush = millis();
mode++;
if (mode > 4) mode = 0;
long knobValue = encoder.read() / 1;
long ledPosition = normalize(knobValue, NUM_LEDS);
long colorValue = normalize(knobValue * 5, WHEEL_SIZE);
long sleepValue = abs(knobValue) % 500;
switch(mode) {
// off
case 0: initializeToBlack();
// all on, White
case 1: for (int i =0; i < NUM_LEDS; i++) {
strip.fill(white, 0, 60);
// all on, knob makes rainbow
case 2: for (int i =0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, colorWheel(BRIGHTNESS, colorValue));
// Rainbow
case 3: rainbow(20);
// slug of rainbow auto moving lights, knob adjusts speed
case 4: initializeToBlack();
strip.show();
// given a wheel position in 0-255 range
// return a rainbow color adjusted by intensity 0 to 1.0
uint32_t colorWheel(float intensity, byte wheelPos)
const int WHEEL_THIRD = (WHEEL_SIZE - 1) / 3;
if (intensity < 0.0 ) intensity = 0.0;
if (intensity > 1.0) intensity = 1.0;
// as wheelPos progresses from 0 to 255 once, colorIndex should progress from 0 to 255 3 times
// find out position in current third of wheel then multiple by 3 to get full color value
byte colorIndex = (wheelPos % WHEEL_THIRD) * 3;
int fadeColor = (255 - colorIndex) * intensity; // color going down
int increaseColor = colorIndex * intensity; // color going up
switch (wheelPos / WHEEL_THIRD) {
case 0: // first third of the wheel, red fading, no green, blue increasing
return Adafruit_NeoPixel::Color(fadeColor, 0, increaseColor);
case 1: // second third of the wheel no red, green increasing, blue fading
return Adafruit_NeoPixel::Color(0, increaseColor, fadeColor);
case 2: // last third of the wheel, red increasing, green fading, no blue
return Adafruit_NeoPixel::Color(increaseColor, fadeColor, 0);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
