Hey everyone, I'm making a Rc car right now and I wanted to code it using an Arduino. For example, I wanted to use a screen to input a certain distance. Using this distance my Arduino would talk to the ESC which (I think?) should activate the motor. I plan on calculating the distance travelled use a rotary encoder. I'll list my materials below. The main problem I'm having right now is figuring out how to wire this all together (without a breadboard if possible) and then code it. If anyone from the community code give me guidance on this, I would EXTREMELY appreciate it. Thank you!
Motor ESC Combo -
MAMBA X SCT, SENSORED, 25.2V WP ESC AND 1410-3800KV 5MM COMBO (castlecreations.com)
Encoder -
Signswise Incremental Optical Rotary Encoder for Arduino 600P/R Wide Voltage Power Supply DC 5-24V 6mm Shaft Quadrature: Amazon.com: Industrial & Scientific
Screen -
Amazon.com: HiLetgo 1602 LCD Keypad Shield 1602 LCD Expansion Shield Board Blue Backlight 4.5-5.5V for Arduino Duemilanove Robot : Electronics
My arduino-
Amazon.com: Arduino Uno REV3 [A000066] : Electronics
Also Sorry I forgot to include that the arduino and ESC are being powered seperatly
You have a lot of empty spaces. Draw what you believe to be a block diagram of every device you believe you will need.
