Caused by: java.io.IOException
Hello, im new in arduino boards, i made a code try ti compile it but it says this:
processing.app.debug.RunnerException
	at cc.arduino.Compiler.callArduinoBuilder(Compiler.java:317)
	at cc.arduino.Compiler.loadPreferences(Compiler.java:216)
	at cc.arduino.Compiler.build(Compiler.java:175)
	at processing.app.SketchController.build(SketchController.java:647)
	at processing.app.SketchController.exportApplet(SketchController.java:672)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: Cannot run program "C:\Program Files (x86)\Arduino\arduino-builder": CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
	at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
	at cc.arduino.Compiler.callArduinoBuilder(Compiler.java:297)
	... 6 more
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
	at java.lang.ProcessImpl.start(ProcessImpl.java:137)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
	... 8 more
So i downloaded random code and try to compile it too, but same error happens again!
I need fast answer i tried to reinstall and delete files in AppData/Local and Roaming, but it won’t work!!!
Using newest IDE and windows 8.1 pro.
Uninstall and remove C:\Program Files (x86)\Arduino if present.
No such a file found. I just deleted it again and installed it, same error.
Does the file C:\Program Files (x86)\Arduino\arduino-builder.exe exist?
There are no folder named Arduino in C:/Program Files (x86).
Try using the "Windows ZIP file for non admin install" download from:
