Hey All
I'm totally stuck on this wireless USB project, and hopefully you could shed some light:
I've been having some issues with my 3v 16mhz Keyestudio Pro Micro's and CC1101 transceivers, and haven't been able to make them talk wirelessly.
I am running very simple test code with them, but whenever I upload the receiver code to them, the receiver runs 1000 spaces/second on the serial monitor even when the transmitter module is not connected. I have augmented the Elechouse library to work with the pro micro through ISP and will included the augmented library. Any help would be really great.
End goal is to make a simple long range wireless keyboard over 433 mHz, so I need to use a 32u4 chip, and like the cc1101 if I can ever get them to work >:(
I am running the Keyestudio as Arduino Genuino Micro, but have tried it as Sparkfun Pro Micro as well. It'll work as a 5v 16mhz pro micro, is the problem maybe that the cc1101 needs to see 8khz?
These are my pin connections between the two:
CC1101 Arduino ProMicro
GND GND
VCC VCC (3.3V)
MOSI MOSI (16)
MISO MISO (14)
SCK SCLK (15)
GD02 A0 (18)
GD00 A1 (19)
CSN A10 (10)
#define SCK_PIN 15
#define MISO_PIN 14
#define MOSI_PIN 16
#define SS_PIN 10
#define GDO0 19
#define GDO2 18
Elechouse Link: GitHub - simonmonk/CC1101_arduino: A clone of the ELECHOUSE_CC1101 http://www.elechouse.com library updated for Arduino 1.0 plus.
CC1101_RECEIVER.ino (436 Bytes)
CC1101_TRANSMITTER.ino (266 Bytes)
CC1101_arduino-master 3.zip (20.5 KB)
