CC1101 help to connect and configure for ESP32 and Attiny88
Hi everyone,
I bought a CC1101 board(as07-m1101s) and it has those pins:
GND
GDO2
GDO1
MCE1
SCK
CSN
GDO0
VCC
I opened the ELECHOUSE_CC1101_SRC_DRV.cpp to see the pins used for connecting initially the board with the esp32:
void ELECHOUSE_CC1101::setSpi(void){
  if (spi == 0){
  #if defined __AVR_ATmega168__ || defined __AVR_ATmega328P__
  SCK_PIN = 13; MISO_PIN = 12; MOSI_PIN = 11; SS_PIN = 10;
  #elif defined __AVR_ATmega1280__ || defined __AVR_ATmega2560__
  SCK_PIN = 52; MISO_PIN = 50; MOSI_PIN = 51; SS_PIN = 53;
  #elif ESP8266
  SCK_PIN = 14; MISO_PIN = 12; MOSI_PIN = 13; SS_PIN = 15;
  #elif ESP32
  SCK_PIN = 18; MISO_PIN = 19; MOSI_PIN = 23; SS_PIN = 5;
  #else
  #endif
So for esp32:
GND → GND
GDO2 → 14 (basically it can be “any” pin)
GDO1 → 19 (is DGO1 the miso?)
MCE1 → NO IDEA?
SCLK → 18 (is SCLK same as SCK??)
CSN → 5 (is this the SS pin?)
GDO0 → 23 (IS GDO0 the mosi?)
VCC → VCC
For attiny88 since there is no special configuration for this processor can i just go on the last line and replace the pin numbers?
#else
would attiny88 fall into the else ?
Thank you
You failed to post a link to your hardware. An identically named board on alibaba.com doesn’t have an MCE1 pin but a MOSI pin (may be a very bad print, might show the quality of the whole board).
GD=1 is MISO, GDO2 is IRQ, CSN is chip select (SS), SCKL is SCK.
Post complete code if you need more help!
