Cc1plus.exe: warning: unrecognized command line option '-Wno-frame-address' exit status 1 'class NexText' has no member named 'PopCallBack'
Hi, any idea about this error.
C:\Users\Josia\Desktop\Ali Yasir\Zeitwaage\Zeitwaage.ino: In function 'void setup()':
Zeitwaage:217:13: error: 'class NexText' has no member named 'PopCallBack'
LiftAngle.PopCallBack(LiftAnglePopCallBack);
At global scope:
cc1plus.exe: warning: unrecognized command line option '-Wno-frame-address'
exit status 1
//#include <SoftwareSerial.h>
#include <Nextion.h>
#include <filters.h>
#include <SPI.h>
#define SS 5
   Filter Setting, LPF
const float cutoff_freq   = 125.0;                /* Cutoff frequency in Hz */
const float sampling_time = 0.001;                /* Sampling time in seconds. */
IIR::ORDER  order  = IIR::ORDER::OD4;             /* Order (OD1 to OD4) */
Filter f(cutoff_freq, sampling_time, order);
   Variables
int n = 0;
int count = 0;
int start_time;
int end_time;
uint16_t number;
const unsigned long event = 5000;
   Nextion Function
void ButtonMinusPopCallBack(void *ptr);
void ButtonPlusPopCallBack(void *ptr);
void ButtonWeiterPopCallBack(void *ptr);
void ButtonEnterPopCallBack(void *ptr);
void ButtonClosePopCallBack(void *ptr);
void LiftAnglePopCallBack(void *ptr);
   Nextion component for page0
NexButton ButtonWeiter = NexButton(0, 1, "ButtonWeiter");
   Nextion component for page1
NexText LiftAngle =   NexText(1, 1, "LiftAngle");
NexButton ButtonMinus = NexButton(1, 2, "ButtonMinus");
NexButton ButtonPlus =  NexButton(1, 3, "ButtonPlus");
NexButton ButtonEnter = NexButton(1, 4, "ButtonEnter");
   Nextion component for page2
NexButton ButtonClose = NexButton(2, 1, "ButtonClose");
NexText Rate =        NexText(2, 2, "Rate");
NexText Amplitude =   NexText(2, 3, "Amplitude");
NexText BeatError =   NexText(2, 4, "BeatError");
NexText BeatRate =    NexText(2, 5, "BeatRate");
   Nextion screens
NexPage zero = NexPage(0, 0, "zero");
NexPage one = NexPage(1, 0, "one");
NexPage two = NexPage(2, 0, "two");
   Buffer zone of various variables
char buffer[100] = {0};
char buffer_Rate[10] = {0};
char buffer_Amplitude[10] = {0};
char buffer_BeatError[10] = {0};
char buffer_BeatRate[10] = {0};
char buffer_LiftAngle[10] = {0};
NexTouch *nex_listen_list[] =
  &ButtonClose,
  &ButtonEnter,
  &ButtonPlus,
  &ButtonMinus,
  &ButtonWeiter,
  &LiftAngle,
  NULL
   Lift Angle Function
  dbSerialPrintln("LiftAnglePopCallBack");
  LiftAngle.setText("52");
   Button Minus Function
  uint16_t len;
  dbSerialPrintln("ButtonMinusPopCallBack");
  memset(buffer, 0, sizeof(buffer));
  LiftAngle.getText(buffer, sizeof(buffer));
  number = atoi(buffer);
  number -= 1;
  itoa(number, buffer, 10);
  LiftAngle.setText(buffer);
   Button Plus Function
  uint16_t len;
  dbSerialPrintln("ButtonPlusPopCallBack");
  number += 1;
   Button Weiter Function
  dbSerialPrintln("ButtonWeiterPopCallBack");
  Serial.print("page one");
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
   Button Enter Function
  int time_elapsed = (start_time - end_time)/1000;
  float Rate = (count/time_elapsed*10)*24*3600;               //Beat rate per day
  float BeatError = (start_time - end_time)/10;               //Divided by 10 because we using 10 beats
  int lift_time = (start_time-end_time)/3*1000;               //Divided by 3 becuase we want to calculate time between first and third tick
  uint16_t lift_angle = number;
  float Amplitude = lift_angle / (2 * sin(180 * lift_time * Rate / 7200));
  float BeatRate = 36600;                   //per hour
  float Frequency = BeatRate / 3600;
  dbSerialPrintln("ButtonEnterPopCallBack");
  Serial.print("page two");
  Serial.print("Rate.txt=");
  Serial.print(Rate);
  Serial.print("Amplitude.txt=");
  Serial.print(Amplitude);
  Serial.print("BeatError.txt=");
  Serial.print(BeatError);
  Serial.print("BeatRate.txt=");
  Serial.print(BeatRate);
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
   Button Close Function
  dbSerialPrintln("ButtonClosePopCallBack");
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
void setup(void)
  Serial.begin(9600);                     /* initialization of serial communication */
  SPI.begin();                            /* initialization of SPI port */
  SPI.setDataMode(SPI_MODE0);             /* configuration of SPI communication in mode 0 */
  SPI.setClockDivider(SPI_CLOCK_DIV64);   /* configuration of clock at 1MHz */
  pinMode(SS, OUTPUT);
  Serial.println("Start");
  nexInit();
   Register all event callback function of all component.
  ButtonPlus.attachPop(ButtonPlusPopCallBack);
  ButtonMinus.attachPop(ButtonMinusPopCallBack);
  ButtonEnter.attachPop(ButtonEnterPopCallBack);
  ButtonClose.attachPop(ButtonClosePopCallBack);
  ButtonWeiter.attachPop(ButtonWeiterPopCallBack);
  dbSerialPrintln("Setup done");
void loop(void)
  nexLoop(nex_listen_list);     /* When a pop or push event occured every time, the corresponding component[right page id and component id] in touch event list will be asked. */
  int16_t* samples;
  samples = (int16_t*)malloc(sizeof(int16_t)*100);
  if(millis()>event)
    if(samples == NULL)
      Serial.print("insufficient memory");
      float filteredval = f.filterIn(MIC3_getSound());
      samples[n++] = filteredval;
  if(*samples>18000)
    count++;
    start_time = millis();
    if(count>=10)
      end_time = millis();
  /*int time_elapsed = (start_time - end_time)/1000;
  int lift_angle = 52;
  float Frequency = BeatRate / 3600;*/
  Serial.println(*samples);
  free(samples);
  n = 0;
int MIC3_getSound(void) {
  digitalWrite(SS, LOW);                                        //activate chip select
  int sound = SPI.transfer(0) | (SPI.transfer(0) << 8);         //reconstruct 12-bit data
  digitalWrite(SS, HIGH);                                       //deactivate chip select
  return sound;
Yes. The error is that 'class NexText' has no member named 'PopCallBack' just like it says.
Should this line:
be:
LiftAngle.attachPop(LiftAnglePopCallBack);
thanks ToddL1962
