HI everyone I'm from Mexico and I want to use the CC3000 wifi module from adafruit to updtae a channel/channels into Thingspeak, so I modify a code from xively and from a Thingspeak project, so I obtain something like this, what do you tink? .
#include <SPI.h>
// Librerias
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "DHT.h"
#include<stdlib.h>
// Definimos los pines del shield
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Definimos el sensor DHT
#define DHTPIN 35
#define DHTTYPE DHT11
// Se crean las instancias del shield
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2); // you can change this clock speed
// Instancias del sensor
DHT dht(DHTPIN, DHTTYPE);
// Parametros de la red a conectarse
#define WLAN_SSID "XXXX"
#define WLAN_PASS "XXXX"
//La seguridad puede ser WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
// Configuracion de Thingspeak
char site[]= "api.thingspeak.com";
String APIKey = "XXXX";
const int updateThingSpeakInterval = 15000; // Time interval in milliseconds to update ThingSpeak (number of seconds * 1000 = interval)
// Variable para alojar la ip de thingspeak
uint32_t ip;
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
void setup(void)
// Iniciamos el sensor
dht.begin();
// Iniciamos el monitor serial
//Inciamos el shield
if (!cc3000.begin())
Serial.println(F("El shield no puede inciar, ¿Esta bien conectado?"));
while(1);
// Conectamos a la red
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println("Conexion establecida");
// Solicitamos un IP
Serial.println(F("Solicitando IP"));
while (!cc3000.checkDHCP())
delay(100);
// Obteniendo la IP del sitio
ip = 0;
Serial.print(site); Serial.print(F(" -> "));
while (ip == 0) {
if (! cc3000.getHostByName(site, &ip)) {
Serial.println(F("No se puede obtener la ip"));
cc3000.printIPdotsRev(ip);
void loop(void)
//Obteniendo la humedad y la temperatura
float h = dht.readHumidity();
float t = dht.readTemperature();
// Transformando los datos a un String
String temperature = String((int) t);
String humidity = String((int) h);
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
//Actualizamod el feed
if(client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval))
updateThingSpeak("field1="+temperature);
while (client.connected()) {
while (client.available()) {
// Read answer
char c = client.read();
Serial.println("Closing connection");
Serial.println("");
client.close();
lastConnected = client.connected();
void updateThingSpeak(String Data)
if (client.connected())
client.println("POST /update HTTP/1.1\n");
client.println("Host: api.thingspeak.com\n");
client.println("Connection: close\n");
client.println("X-THINGSPEAKAPIKEY: "+APIKey+"\n");
client.println("Content-Type: application/x-www-form-urlencoded\n");
client.println("Content-Length: ");
client.println(Data.length());
client.println("\n\n");
client.println(Data);
lastConnectionTime = millis();
Serial.println("Connecting to ThingSpeak...");
failedCounter = 0;
failedCounter++;
Serial.println("Connection to ThingSpeak failed ("+String(failedCounter, DEC)+")");
failedCounter++;
Serial.println("Connection to ThingSpeak Failed ("+String(failedCounter, DEC)+")");
If you have some idea of what i can add, you are welcome
