I’m trying to setup a simple ‘send email on event’ using the PushingBox API and an Arduino UNO + CC3000 WiFi shield and while everything appears to be okay, I can’t establish a connection using the sketch PushingBox provides. When run, the Serial Monitor windows displays:
"Attempting to connect to WPA network…
Couldn’t get a wifi connection"
That’s as far as I get. I know the boards work because I successfully tested the setup using the Temboo API (I prefer PushingBox.)
As an aside the router is an N600 with WPA2-PSK AES security
Any help would be greatly appreciated.
The sketch was copied from GitHub
https://github.com/Clement87/PushingBox-for-Arduino-WiFi-shield
// General code from http://www.pushingbox.com for Arduino WiFI shield (official) v1.0
#include <WiFi.h>
// MODIFY HERE //
char wifissid[] = "mySSID"; // your network SSID (name)
char wifipass[] = "myPASSWORD"; // your WPA network password
char DEVID1[] = "myPushingBoxID"; //Scenario : "The mailbox is open"
//Numeric Pin where you connect your switch
uint8_t pinDevid1 = 3; // Example : the mailbox switch is connect to the Pin 3
// Debug mode
boolean DEBUG = true;
// End //
char serverName[] = "api.pushingbox.com";
boolean pinDevid1State = false; // Save the last state of the Pin for DEVID1
boolean lastConnected = false;
int status = WL_IDLE_STATUS; // the Wifi radio's status
WiFiClient client;
// initialize serial:
pinMode(pinDevid1, INPUT);
// attempt to connect using WPA2 encryption:
Serial.println("Attempting to connect to WPA network...");
status = WiFi.begin(wifissid, wifipass);
// if you're not connected, stop here:
if ( status != WL_CONNECTED) {
Serial.println("Couldn't get a wifi connection");
while(true);
// if you are connected, print out info about the connection:
else {
Serial.println("Connected to network");
// Listening for the pinDevid1 state
if (digitalRead(pinDevid1) == HIGH && pinDevid1State == false) // switch on pinDevid1 is ON
if(DEBUG){Serial.println("pinDevid1 is HIGH");}
pinDevid1State = true;
//Sending request to PushingBox when the pin is HIGHT
sendToPushingBox(DEVID1);
if (digitalRead(pinDevid1) == LOW && pinDevid1State == true) // switch on pinDevid1 is OFF
if(DEBUG){Serial.println("pinDevid1 is LOW");}
//Sending request to PushingBox when the pin is LOW
//sendToPushingBox(DEVID1); //Here you can run an other scenario by creating a DEVID2 variable
//DEBUG part
// this write the respons from PushingBox Server.
// You should see a "200 OK"
if (client.available()) {
char c = client.read();
if(DEBUG){Serial.print(c);}
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
if(DEBUG){Serial.println();}
if(DEBUG){Serial.println("disconnecting.");}
client.stop();
lastConnected = client.connected();
//Function for sending the request to PushingBox
void sendToPushingBox(char devid[]){
client.stop(); if(DEBUG){Serial.println("connecting...");}
if(client.connect(serverName, 80)) {
if(DEBUG){Serial.println("connected");}
if(DEBUG){Serial.println("sendind request");}
client.print("GET /pushingbox?devid=");
client.print(devid);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(serverName);
client.println("User-Agent: Arduino");
client.println();
else {
if(DEBUG){Serial.println("connection failed");}
