Hi everyone,
I have a problem with my cc3000.
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include “utility/debug.h”
#include “DHT.h”
#include<stdlib.h>
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER); // you can change this clock speed
// WLAN parameters
#define WLAN_SSID “ssid”
#define WLAN_PASS “pass”
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000 // Amount of time to wait (in milliseconds) with no data
// received before closing the connection. If you know the server
// you’re accessing is quick to respond, you can reduce this value.
#define DHTPIN A4
#define DHTTYPE DHT11
int sensorPin=A5;
WiFiClient client;
uint32_t ip;
DHT dht(DHTPIN, DHTTYPE);
int isik,nem,gaz,sicaklik;
const unsigned long connectTimeout = 15L * 1000L;
void setup(void)
//Serial.begin(115200);
Serial.println(F("\nInitializing…"));
if (!cc3000.begin())
Serial.println(F(“Couldn’t begin()! Check your wiring?”));
while(1);
Serial.print(F("\nAttempting to connect to "));
Serial.println(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F(“Failed!”));
while(1);
Serial.println(F(“Connected!”));
Serial.println(F(“Request DHCP”));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
///if he login and he can show info/ mean he login and only then continue
while (! displayConnectionDetails()) {
//client.connect(“idriskaraali.azurewebsites.net”,80);
if (client.connect(“idriskaraali.azurewebsites.net”,80))//PROBLEM WAS HERE!
//client.println();
Serial.println(“Baglandi!”);
Serial.println(“Cannot connect to Server”);
void loop(void)
float h = dht.readHumidity(); //nem ölçümü
float t = dht.readTemperature(); //sicaklik ölçümü
int sicaklik = (int) t;
int nem = (int) h;
isik=analogRead(sensorPin);
client.print(“POST /add.php?nem=”); client.print(nem);
client.print("&sicaklik="); client.print(sicaklik);
client.print("&gaz="); client.print(nem2);
client.print("&isik="); client.print(isik);
//client.print(temp);
client.print(" HTTP/1.1");
client.println();
Serial.println(“GET /add.php HTTP/1.1 Ekliyor!”);
client.println(“Host: idriskaraali.azurewebsites.net”);
//client.println(“Content-Type: application/x-www-form-urlencoded”);
//client.println(“Connection: close”);
/client.println(“User-Agent: Arduino/1.0”);
client.print("Content-Length: ");
client.println(temp.length());
client.println();
client.print(temp);/
Serial.print(nem);
Serial.print("–");
Serial.print(sicaklik);
Serial.print("–");
Serial.print(nem2);
Serial.print("–");
Serial.println(isik);
client.println();
client.stop();
client.flush();
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
//Serial.println(F(“Unable to retrieve the IP Address!\r\n”));
return false;
Serial.print(F("\nIP Addr: “)); cc3000.printIPdotsRev(ipAddress);
Serial.print(F(”\nNetmask: “)); cc3000.printIPdotsRev(netmask);
Serial.print(F(”\nGateway: “)); cc3000.printIPdotsRev(gateway);
Serial.print(F(”\nDHCPsrv: “)); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F(”\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
It was work my Ethernet modules. But did not work with cc3000.
Thank You All.
