CC3000 library Port
Has anyone ported the CC3000 library (from Adafruit for example) to another Micro Platform?
I'm in the process of porting it to PSOC4 and looking for some advice on pitfalls to look out for etc...
The CC3000 library from Adafruit is already ported from the original code published by Texas Instruments; my guess is you’d have an easier time porting the original code than Adafruit’s because then you won’t have to deal with any Arduino/ATMega specifics.
TI’s Wiki is here: http://processors.wiki.ti.com/index.php/CC3000, you will probably be interested in the section “Host Driver Porting” which should be enough to get you started. They also have a forum where you’ll find many threads on porting the CC3000 library to different MCUs.
Good luck!
