First off, I don't know if I'm posting in the correct section, I looked at the descriptions and this one seemed to fit the best. If I am wrong please accept my apology and maybe point me to the area I should be in. If I am in the correct area then I have a problem. I'm trying to build a home automation sketch using an Arduino Mega 2560, a CC3000 WIFI (stackable), and an eight channel relay board I got off of eBay.
I found some code on the Internet (https://www.openhomeautomation.net/wireless-relay-arduino-wifi) so I copied and modified it to suit my needs since I am brand new to coding and very poor to boot. The problem is that I can't seem to get past this declaration problem to go away. When I try to compile the sketch I get an error that says "CC3000 was not declared in this scope." I Googled this and the results I found didn't help so I tried adding brackets where I thought they should go and when that didn't work, I tried adding a line before (and after) the void setup() statement that said "int CC3000" but all that did was break it worse.
Any help would be greatly appreciated. If you are able to give me a solution please tell me where in the sketch it would go as well as the actual syntax (yes, I'm that bad, Lol). Once again thank you for your help and I hope you have a great day!
Here's my code:
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include <CC3000_MDNS.h>
#include <Ethernet.h>
#include <aREST.h>
#include "DHT.h"
#define WLAN_SSID "MySSID" // cannot be longer than 32 characters!
#define WLAN_PASS "MyPassWord!"
#define WLAN_SECURITY WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define LISTEN_PORT 8092
//Adafruit_CC3000_Server restServer(LISTEN_PORT);
//MDNSResponder mdns;
//aREST rest = aREST();
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
if (!mdns.begin("arduino", cc3000)) {
while(1);
restServer.begin();
So I've been at this for almost a week before I decided to post for help. Does anyone have anything better to offer than what I see so far? My first post didn't do so well either, most people were not interested in helping but rather telling me just how misguided I am. Is there a better forum to post to that maybe someone can point me to? Thanks.
Hi Delta, and thanks for the pointers. To answer your question, no I don't know how to use the libraries or how to create instances. I lack the necessary education to build code from scratch. Rather I find a completed project on the Internet and then modify it to suit my needs. I do lots of research before I start posting questions, that's how I built my first home automation system which uses an Ethernet shield. So now I'm looking to take it to the next level by using the CC3000 wireless shield but I have to get it working first before taking the next steps. Thanks again and I look forward to any assistance you can offer. Have a great day.
This might be pointless explaining without knowing the basics with C++, but you generally have classes in c++. A class would contain all the relevant information for what it is trying to describe, for example, the class "Car" might include variables such as "numberOfDoors", "EngineCapacity", "Model" etc.
So then to use this class, we would create an instance, for a Ford Focus for example, and we would fill in all the variables specified above. We then want another car, a Fiat Punto, so we then create another instance, and fill in all those variables for the Fiat Punto.
So back to your issue. The library contains the class, the class is called "Adafruit_CC3000". The constructor in the header file also shows that you need to specify some information, specifically pins, regarding where you wired the shield into your arduino. So you need something like this above your setup():
Adafruit_CC3000 cc3000( 8, 9, 10 );
You'll need to change 8, 9, 10 to whatever pins you used when wiring it to your arduino.
Thank you very much everyone, I will definitely try the code you suggest, as well as learning some c++. I've never done any coding before so it will be a challenge. But thanks again for your help and I'll keep you posted as to my progress. Take care, until later...
