Cc3000 Wi-fi shield from Keyes
"Keyes" is apparently a Chinese clone manufacturer with decent standard. I own one of their wifi shields, a CC3000 based one with SD card support.
I've tried it with the libraries and examples provided by both Adafruit and Sparkfun for their versions of the same shield, but when I connect to my home network all that prints on my serial monitor is gibberish. It seems like something is happening though, because it prints lines and lines of gibberish like its receiving data.
The strange thing is that there are simple text lines specified in the setup part of the Arduino code: ("trying to connect to server") and such. And still only strange, five character long mesages in the prompt.
I will post the Adafruit code later tonight if needed. I'm on my phone right now.
Does anyone have any experience with this shield? And troubleshooting it? I'm afraid I'm too inexperienced to crack this one solo.
If you need help, it is.
Does the Serial Monitor baud rate match that in the code? It sounds like they do not.
Yes, Im sorry, never got hold of my computer yesterday :(. I will post as soon as I can. I will look into the baud rate issue as soon as I can! Great tip!
Ok, sorry for the delay. Here's the code, straight from the Adafruit library examples.
This example does a test of the TCP client capability:
  * Initialization
  * Optional: SSID scan
  * AP connection
  * DHCP printout
  * DNS lookup
  * Optional: Ping
  * Connect to website and print out webpage contents
  * Disconnect
SmartConfig is still beta and kind of works but is not fully vetted!
It might not work on all networks!
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "myNetwork"           // cannot be longer than 32 characters!
#define WLAN_PASS       "myPassword"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS  3000      // Amount of time to wait (in milliseconds) with no data
                                   // received before closing the connection.  If you know the server
                                   // you're accessing is quick to respond, you can reduce this value.
// What page to grab!
#define WEBSITE      "www.adafruit.com"
#define WEBPAGE      "/testwifi/index.html"
    @brief  Sets up the HW and the CC3000 module (called automatically
            on startup)
uint32_t ip;
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  // Optional SSID scan
  // listSSIDResults();
  Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  ip = 0;
  // Try looking up the website's IP address
  Serial.print(WEBSITE); Serial.print(F(" -> "));
  while (ip == 0) {
    if (! cc3000.getHostByName(WEBSITE, &ip)) {
      Serial.println(F("Couldn't resolve!"));
  cc3000.printIPdotsRev(ip);
  // Optional: Do a ping test on the website
  Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
  replies = cc3000.ping(ip, 5);
  Serial.print(replies); Serial.println(F(" replies"));
  /* Try connecting to the website.
     Note: HTTP/1.1 protocol is used to keep the server from closing the connection before all data is read.
  Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
  if (www.connected()) {
    www.fastrprint(F("GET "));
    www.fastrprint(WEBPAGE);
    www.fastrprint(F(" HTTP/1.1\r\n"));
    www.fastrprint(F("Host: ")); www.fastrprint(WEBSITE); www.fastrprint(F("\r\n"));
    www.println();
    Serial.println(F("Connection failed"));
    return;
  Serial.println(F("-------------------------------------"));
  /* Read data until either the connection is closed, or the idle timeout is reached. */
  unsigned long lastRead = millis();
  while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
    while (www.available()) {
      char c = www.read();
      Serial.print(c);
  www.close();
  /* You need to make sure to clean up after yourself or the CC3000 can freak out */
  /* the next time your try to connect ... */
  Serial.println(F("\n\nDisconnecting"));
  cc3000.disconnect();
void loop(void)
    @brief  Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
  uint32_t index;
  uint8_t valid, rssi, sec;
  char ssidname[33];
  if (!cc3000.startSSIDscan(&index)) {
    Serial.println(F("SSID scan failed!"));
    return;
  Serial.print(F("Networks found: ")); Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : ")); Serial.print(ssidname);
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
  cc3000.stopSSIDscan();
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
And yes, naturally I did set the SSID name and password.
Hmmm... well, this is embarrassing. It seems like the only issue here was the baud rate, like Paul S wrote. Missed that lesson in Arduino kindergarten. Well, hopefully this post quickly scrolls down into oblivion. And thanks Paul S!
Hi my keyes shield hangs up after like 5 minutes any solutions??
