Hi!
So I got some idea and I need to build own scanner.
I tried to get some sensors from few old scanners and finally found one which I was able to find datasheet - µPD3799CY from NEC (attachment).
So connected it as suggested in datasheet except resistors, NOT-gates and preamp - input directly from arduino, output (V_out3) directly to arduino. Power supply - 12V.
I analyzed bilion times graph on page 8 and tried to make program:
int fiRB = 8;
int fi1 = 9;
int fi2 = 10;
int fiTG = 11;
int line = 0;
// PORTB maps to Arduino digital pins 8 to 13
// The two high bits (6 & 7) map to the crystal pins and are not usable;
// PORTB = {X1} {X2} {13} {12} {11} {10} {9} {8};
// PORTB = {X1} {X2} {13} {12} {fiTG} {fi1} {fi2} {RB};
// PORTB = 00000000;
pinMode(fiRB, OUTPUT);
pinMode(fi1, OUTPUT);
pinMode(fi2, OUTPUT);
pinMode(fiTG, OUTPUT);
pinMode(A0, INPUT);
delay(100);
Serial.println("");
Serial.println("Hit enter for measurement.");
line = 0;
Serial.println("Waiting for input.");
while(!Serial.available()){}
while( Serial.available()){ Serial.read(); }
PORTB = B00000100;
delayMicroseconds(1);
PORTB = B00000101;
PORTB = B00000011;
// PORTB = {X1} {X2} {13} {12} {fiTG} {fi1} {fi2} {fiRB};
for(int k=1; k<20; k++){
for(int f = 0; k < 3; k++){
PORTB = B00000100;
PORTB = B00000101;
PORTB = B00000011;
line++;
Serial.print(line++);
Serial.print('\t');
PORTB = B00000100;
Serial.print("B00000100");
Serial.print(":");
Serial.print(analogReadFast(A0));
Serial.print(" ");
PORTB = B00000101;
Serial.print("B00000101");
Serial.print(":");
Serial.print(" ");
PORTB = B00000011;
Serial.print("B00000011");
Serial.print(":");
Serial.println(analogReadFast(A0));
Serial.println("---------");
for(int j=0; j < 6; j++){
for(int i=1; i<900; i++){
line++;
PORTB = B00000100;
PORTB = B00000101;
PORTB = B00000011;
Serial.print('\t');
PORTB = B00000100;
Serial.print(":");
Serial.print(" ");
PORTB = B00000101;
Serial.print(":");
Serial.print(" ");
PORTB = B00000011;
Serial.print(":");
Serial.println("");
int analogReadFast(byte ADCpin)
{ byte ADCSRAoriginal = ADCSRA;
ADCSRA = (ADCSRA & B11111000) | 4;
int adc = analogRead(ADCpin);
ADCSRA = ADCSRAoriginal;
return adc;
The problem is that when I cover whole sensor, I get this:
2 B00000100:1023 B00000101:1023 B00000011:1023
5 B00000100:1023 B00000101:1023 B00000011:1023
8 B00000100:1023 B00000101:1023 B00000011:1023
11 B00000100:1023 B00000101:1023 B00000011:1023
14 B00000100:1023 B00000101:1023 B00000011:1023
17 B00000100:1023 B00000101:1023 B00000011:1023
20 B00000100:1023 B00000101:1023 B00000011:1023
23 B00000100:1023 B00000101:1023 B00000011:1023
26 B00000100:1023 B00000101:1023 B00000011:1023
29 B00000100:1023 B00000101:1023 B00000011:1023
32 B00000100:1023 B00000101:1023 B00000011:1023
35 B00000100:1023 B00000101:1023 B00000011:1023
38 B00000100:1023 B00000101:1023 B00000011:1023
41 B00000100:1023 B00000101:1023 B00000011:1023
44 B00000100:1023 B00000101:1023 B00000011:1023
47 B00000100:1023 B00000101:1023 B00000011:1023
50 B00000100:1023 B00000101:1023 B00000011:1023
53 B00000100:1023 B00000101:1023 B00000011:1023
56 B00000100:1023 B00000101:1023 B00000011:1023
956 B00000100:1023 B00000101:1023 B00000011:1023
1856 B00000100:1023 B00000101:1023 B00000011:1023
2756 B00000100:1023 B00000101:1023 B00000011:1023
3656 B00000100:1023 B00000101:1023 B00000011:1023
4556 B00000100:1023 B00000101:1023 B00000011:1023
5456 B00000100:1023 B00000101:1023 B00000011:1023
Torch directly onto sensor:
2 B00000100:729 B00000101:452 B00000011:481
5 B00000100:1023 B00000101:487 B00000011:491
8 B00000100:1023 B00000101:531 B00000011:531
11 B00000100:1023 B00000101:532 B00000011:534
14 B00000100:1023 B00000101:531 B00000011:531
17 B00000100:1023 B00000101:512 B00000011:511
20 B00000100:1023 B00000101:539 B00000011:538
23 B00000100:1023 B00000101:535 B00000011:535
26 B00000100:1023 B00000101:536 B00000011:536
29 B00000100:1023 B00000101:534 B00000011:534
32 B00000100:1023 B00000101:539 B00000011:540
35 B00000100:1023 B00000101:536 B00000011:536
38 B00000100:1023 B00000101:532 B00000011:535
41 B00000100:1023 B00000101:519 B00000011:518
44 B00000100:1023 B00000101:534 B00000011:534
47 B00000100:1023 B00000101:534 B00000011:535
50 B00000100:1023 B00000101:534 B00000011:534
53 B00000100:1023 B00000101:533 B00000011:532
56 B00000100:1023 B00000101:535 B00000011:536
956 B00000100:1023 B00000101:492 B00000011:495
1856 B00000100:1023 B00000101:489 B00000011:494
2756 B00000100:1023 B00000101:489 B00000011:494
3656 B00000100:1023 B00000101:489 B00000011:494
4556 B00000100:1023 B00000101:489 B00000011:494
5456 B00000100:1023 B00000101:487 B00000011:494
Until now it seems to be everything ok, but I've covered about 1/3 of sensor with green tape and the output is the same...
I've been trying different delays (after PORTB) and whole bunch of stuff i can do with software, but it seems to not affect the output. Even removing part before first for does not change anything...
UPD3799CY (3x 5k pix).pdf (118 KB)
