Hi , i want to ask how to change operation mode of this sensor. In datasheet it is stated that i change a register on this chip but how i change register bit on a i2c device. The code and the datasheet is in the image
tasos1234567890:
the Adafruit_CCS811 library has a funtion for that:
setDriveMode();
and the mode available in the library as well:
CCS811_DRIVE_MODE_IDLE = 0x00
CCS811_DRIVE_MODE_1SEC = 0x01
CCS811_DRIVE_MODE_10SEC = 0x02
CCS811_DRIVE_MODE_60SEC = 0x03
CCS811_DRIVE_MODE_250MS = 0x04
so to change the mode to '010' all you need to do IMHO is to insert
ccs.setDriveMode(CCS811_DRIVE_MODE_10SEC); after
ccs.begin() in you code.
also I don't think it is necessary need to include wire.begin() in your code based on the example provided.
hope that helps....
thanks man. you saved me 19mA ![]()
