CCS811 ESP8266 Oddities
I'd be grateful for any insight into the following issue I'm experiencing with this I2C sensor.
I'm using an Adafruit-style CCS811 I2C module along with the excellent Adafruit_CCS811.h library.
The Adafruit CCS811_test sensor test sketch works perfectly using an Uno and an ESP-32 devboard however on the ESP8266 (Wemos D1 Mini) I'm getting some odd readings through on serial, below.
The sensor is detected OK using an I2C scanner and ESP8266 has no issues with several other I2C sensors on the same sensor board. I'm confused as to whether this might be a hardware (power) issue from the ESP8266 board or some kind of issue with the library?
I'd be grateful for any insight on this.
Many thanks
Soft WDT reset
stack>>>
ctx: cont
sp: 3ffffd00 end: 3fffffc0 offset: 01a0
3ffffea0: 3ffee528 00000001 3ffee528 402027b8
3ffffeb0: 3ffee528 00000000 00000000 4020287c
3ffffec0: 00000001 3ffee360 3ffee528 4020297e
3ffffed0: 3ffee35f 0000005a 3ffee528 40202999
3ffffee0: 3ffee35f 0000005a 00000001 00000000
3ffffef0: 3ffee338 00000001 3ffee35d 40202c08
3fffff00: 00000001 3fffff60 3ffee35d 402016d0
3fffff10: 3ffee300 0000005a 3ffee34c 402016f8
3fffff20: 00000001 00000000 3ffee34c 4020116d
3fffff30: 00000001 00000000 3fffff70 00000000
3fffff40: 3fffff70 0001321c 3ffee5f0 3ffee4e8
3fffff50: 3fffdad0 3ffee338 3ffee338 3ffee4e8
3fffff60: 3fffdad0 3ffee338 3ffee338 402011ca
3fffff70: 40202d90 00000064 3ffee4e8 402013c6
3fffff80: 3fffdad0 3ffee338 3ffee338 402011e5
3fffff90: 3fffdad0 00000000 3ffee480 4020106e
3fffffa0: feefeffe 00000000 3ffee4a8 40202120
3fffffb0: feefeffe feefeffe 3ffe84e8 40100e0d
<<<stack<<<
If you look at the ESP8266 it states it does not support clock stretching, if you look at the Adafruit data is states it uses clock stretching. Since these are polar opposites I would not expect it to work.
thank you, very helpful..
