CCS811 ID_ERROR 0xE0
I am using the Sparkfun CCS811 air quality sensor and am getting ID_ERROR 0xe0. I am using the basic code from the Sparkfun guide. The code appears to compile just fine. It exits with the .begin().
#include <SparkFunCCS811.h>
#define CCS811_ADDR 0x5B //Default I2C Address
//#define CCS811_ADDR 0x5A //Alternate I2C Address
CCS811 mySensor(CCS811_ADDR);
  Serial.println("CCS811 Basic Example");
  // Return values
typedef enum
    SENSOR_SUCCESS,
    SENSOR_ID_ERROR,
    SENSOR_I2C_ERROR,
    SENSOR_INTERNAL_ERROR
} status;
  //It is recommended to check return status on .begin(), but it is not
  //required.
  CCS811Core::status returnCode = mySensor.begin();
  bool error = mySensor.checkForStatusError();
  Serial.println(error);
  //CCS811Core::status returnCode = mySensor.beginCore();
Serial.print("beginCore exited with: ");
switch ( returnCode )
case CCS811Core::SENSOR_SUCCESS:
  Serial.print("SUCCESS");
case CCS811Core::SENSOR_ID_ERROR:
  Serial.print("ID_ERROR");
case CCS811Core::SENSOR_I2C_ERROR:
  Serial.print("I2C_ERROR");
case CCS811Core::SENSOR_INTERNAL_ERROR:
  Serial.print("INTERNAL_ERROR");
case CCS811Core::SENSOR_GENERIC_ERROR:
  Serial.print("GENERIC_ERROR");
default:
  Serial.print("Unspecified error.");
  if (returnCode != CCS811Core::SENSOR_SUCCESS)
    Serial.println(".begin() returned with an error.");
    while (1); //Hang if there was a problem.
  //Check to see if data is ready with .dataAvailable()
  if (mySensor.dataAvailable())
    //If so, have the sensor read and calculate the results.
    //Get them later
    mySensor.readAlgorithmResults();
    Serial.print("CO2[");
    //Returns calculated CO2 reading
    Serial.print(mySensor.getCO2());
    Serial.print("] tVOC[");
    //Returns calculated TVOC reading
    Serial.print(mySensor.getTVOC());
    Serial.print("] millis[");
    //Simply the time since program start
    Serial.print(millis());
    Serial.print("]");
  delay(10); //Don't spam the I2C bus
Great thanks!
Try the basic example that comes with the library. It contains Wire.begin() before everything. You can also search the web for i2cScanner sketch which will tell you if your device is properly connected to i2c (wire) or not.
Works. Great thanks! :)
