Logic chips like this can have the pins directly connected to either voltage rail. However a 10K to ground makes it look like a logic zero but allows you to easily pull it high later if you want to connect a signal to it.
Thanks! so I know its not essential, I’m just going to connect them direct to ground for now, as thats ok
but if I decide I want to enable/disable the chips for some reason, I add a resistor to ground ( is 10k enough for two chips?) so its enabled by default but use a 5v 'digital out pin to ‘HIGH’ to this enable wire to dissable the chips?
