Central Heating - Arduino or NodeMCU version
Web application of smart home heating.
I will translate project to your language/ or to english.
The system offers a clear web interface where real-time viewing of your home situation (actual temperatures, current output status - pump and boiler thermostat)
The system is adapted to measure 6 temperatures, one of which is used for the thermostat that switches the furnace. The system operates with 0.5 ° C hysteresis. At a set temperature of 20 ° C, it starts to heat at 19.50 ° C and continues to 20 ° C in heating.
Hysteresis can be changed. The second temperature is used for the outdoor temperature for switching the water pump (especially during cold winter months). Everything can run autonomously - automatically according to the logic mentioned above. On request, however, the status may change to ON / OFF as requested by the user of this web application.
Graphs of the current day, of course, with the development of each temperature. Temperature sensors can be placed in strategic locations such as hot water pipes for temperature monitoring, boiler rooms or individual rooms.
The transparent web interface is in the ControlR template that offers interactive web elements. The page is responsive, adapting to the mobile (on the breadth) of the tablet. The user logs in to the web interface, which can be changed directly on the system.
The whole system offers:
Real-time data on the state of the household
Data storage in the database (once every 4 minutes with data over 2 weeks old)
Temperature setting for thermostat
Setting the temperature for the pump
Changing the rendered names in the table (outputs and inputs)
Reset the desktops at a distance
Change your login information
Graphs
If you are interested: martinius96@gmail.com
Arduino code = Arduino (Uno/Mega) + Ethernet shield W5100
NodeMCU code = (Tested under v3 Lolin)
Screenshots:
