Hi everybody.
Platform: Arduino IDE 2.3.4 in a Mac Mini M4 256GB with 24GBRam Sequoia 15.3.1
Installed via settings the CH32V chip (https://github.com/openwch/board_manager_files/raw/main/package_ch32v_index.json)
It seems to do things (like beforeinstall.sh and others related to openocd).
Application: Simple Blink example so no need to describe it.
Compiles without errors.
Connected to WCH-Link and mcu as per instructions.(have teh WCH-Link and MCU board).
Upload is the problem, not that it doesn't find the port, it doesn't get there, it has a dylib not found error, related/called by openocd.
Sketch uses 5376 bytes (32%) of program storage space. Maximum is 16384 bytes.
Global variables use 404 bytes (19%) of dynamic memory, leaving 1644 bytes for local variables. Maximum is 2048 bytes.
dyld[5994]: Library not loaded: /usr/local/opt/libusb/lib/libusb-1.0.0.dylib
Referenced from: <C79B1DDB-9DAE-30AE-9474-2E146265EC5A> /Users/rsn/Library/Arduino15/packages/WCH/tools/openocd/1.0.0/bin/openocd
Reason: tried: '/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (no such file), '/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (no such file), '/usr/local/lib/libusb-1.0.0.dylib' (no such file), '/usr/lib/libusb-1.0.0.dylib' (no such file, not in dyld cache)
Failed uploading: uploading error: signal: abort trap
There is no such directory in osx ->/usr/local/opt and the others.
libusb has been installed via Brew.
Reviewing the package installing scripts we find a beforeinstall.sh that is displayed as being exectued when first installing the CH32Vxxx and simply goes on.
The code inside has linux cmds that are not osx like udevcmd, and ldconfig.
Did cheat by copying the installed libusb required library to the required dir and got
dyld[7201]: Library not loaded: /usr/local/opt/libusb/lib/libusb-1.0.0.dylib
Reason: tried: '/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (no such file), '/usr/local/opt/libusb/lib/libusb-1.0.0.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/usr/local/lib/libusb-1.0.0.dylib' (no such file), '/usr/lib/libusb-1.0.0.dylib' (no such file, not in dyld cache)
So yes, CH32V0003 is not compatible with the MAc Mini 4 ARM.
Perhaps there is a url for mac osx ARM version of the CH32V000?
Kind regards.
