Chaining PWM driver PCA9635
Hello, I want to chain the PCA9635 in i2C.
This IC is very similar to the PCA9685 from adafruit. The only difference is that It has a fixed frequency of 97KHz compared to the PCA9685 with 1.6KHz.
The only library that I was able to get the PCA9635 to work is by rambo:
I don’t have an option to set different boards compared to the adafruit library PCA9685
The code on the adafruit looks pretty simple where I can set my object and then call it:
Adafruit_PWMServoDriver pwm1 = Adafruit_PWMServoDriver(0x40);
Adafruit_PWMServoDriver pwm2 = Adafruit_PWMServoDriver(0x41);
pwm1.begin();
pwm2.begin();
pwm1.setPWM(0, 0, 1000) //(output channel for board, time when HIGH, time when LOW)
pwm2.setPWM(0, 0, 1000)
However, for the PCA9635 library, I am unable to figure out how to do this.
// Get this from https://github.com/rambo/I2C
#include <I2C.h> // For some weird reason including this in the relevant .h file does not work
#include <i2c_device.h> // For some weird reason including this in the relevant .h file does not work
#include <pca9635.h>
#define I2C_DEVICE_DEBUG
// Container for the device
pca9635 driver;
void setup()  {
    // Use the SW-Reset address to reset all pca9635 ICs on the bus
    // Initialize I2C library manually
    I2c.begin();
    I2c.timeOut(500);
    PCA9635.reset(); // Incidentally this global name is a pca9635 instance bound to the generla "all-call" address so it can be used to set global parameters
    // Wake oscillators on all-call
    PCA9635.set_sleep(0x0);
    delayMicroseconds(500);
    // Enable PWM controls for all leds on all-call
    PCA9635.set_led_mode(2);
PCA9635.set_driver_mode(0xff);
    // Set device address and call I2c.begin() (note: your need to change the address to correspond to your device)
driver.begin(0x70, false); // ******** You need to change the device address here, 0x70 is the 7-bit ALL-CALL address for PCA9635 ***********
PCA9635.set_led_pwm(0, 50); // (output channel from 0~15, duty cycle from 0~255)
PCA9635.set_led_pwm(0, 100);
I tried comparing the .cpp files for a few hours to see if I can get it to work with no luck.
Here is the beginning of the adafruit .cpp file:
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
#if defined(ARDUINO_SAM_DUE)
 #define WIRE Wire1
#else
 #define WIRE Wire
#endif
// Set to true to print some debug messages, or false to disable them.
#define ENABLE_DEBUG_OUTPUT false
Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(uint8_t addr) {
  _i2caddr = addr;
void Adafruit_PWMServoDriver::begin(void) {
 WIRE.begin();
 reset();
void Adafruit_PWMServoDriver::reset(void) {
 write8(PCA9685_MODE1, 0x0);
And the beginning of the PCA9635 .cpp file:
#include "pca9635.h"
// Constructor
pca9635::pca9635()
    device_address = 0x70; // Default to the all-call address
    autoincrement_bits = 0x80; // Autoincrement all
void pca9635::begin(byte dev_addr, boolean wire_begin, boolean init)
    i2c_device::begin(dev_addr, wire_begin);
    if (init)
        this->set_sleep(0x0); // Wake up oscillators
        delayMicroseconds(500); // Wait for the oscillators to stabilize
        this->set_led_mode(3); // Default to full PWM mode for all drivers
void pca9635::begin(byte dev_addr, boolean wire_begin)
    pca9635::begin(dev_addr, wire_begin, false);
I attached both libraries for reference.
also a link: http://puu.sh/wTdaD/407c827de2.zip
I would really appreciate it if I could have any kind of advice or lead into doing this. Thank you so much!
PCA lib.zip (4.41 KB)
