Change a nested key inside a json by Arduinojson 5
Hi everybody,
I have a problem changing the value of a nested key inside a json. I couldn't change the mentioned value as below:
"Switches": [
"Name": "Room Ligth",
"state": true
"Sensors": [
"Name": "Home Temperature",
"value": 423 // << this value--------------
what Im looking for is something like this:
root["Sensors"][0]["value"]=423;
but when I write the above line my "Weoms mini D1" crashes and restarts.
huge thanks for any ideas
hamed
can you try this code:
#include <ArduinoJson.h>
char jsonTxt[] = "{\"Switches\": [{\"Name\": \"Room Ligth\",\"state\": true}],\"Sensors\": [{\"Name\": \"Home Temperature\",\"value\": 423}]}";
  DynamicJsonDocument doc(200);
  deserializeJson(doc, jsonTxt);
  long value = doc["Sensors"][0]["value"];
  Serial.print(F("Initial Value = ")); Serial.println(value);
  doc["Sensors"][0]["value"] = 42;
  Serial.print(F("After modification, Value = ")); Serial.println(value);
void loop() {}
if all goes well, Serial Monitor (@ 115200 bauds) will show
Initial Value = 423
After modification, Value = 42
tnx alot J-M-L
