Change a value from json
Hey guys.
I have a question / problem.
I have a string in json format:
{"1000":{"name":"phil", "number":10}, "1001":{"name":"otto", "number":15}}
I would like to change a value for a given field and save that string again, with the field changed:
{"1000":{"name":"phil", "number":12}, "1001":{"name":"otto", "number":15}}
How can I do this?
I have used this site to write and check json :slight_smile:
Put your json in Text and look result in Viewer.
RV mineirin
Thanks, @ruilviana !
But I would like to know how I can change the value of a single field in that json and "update" it again in a string to use it again.
Hi @filipekerplunk .
Analyze your question well!
You ask how to make a change to a string.
But it doesn't say:
Which program is used;
What type of computer or controller or smart phone, etc ... are you using;
It does not say which programming language you are using.
And you want a smart answer?
I suggest you read this topic and redo your question.
RV mineirin
