Hey All,
I'm trying to get my arduino Uno to steer by a compass (works) but I want it to change direction after 10 seconds and I cant seem to get it to work. heres what I have for code so far. IF I drop the "while" statement and just pick one direction or the other, it works fine.
#include <Time.h> //??
unsigned long time = millis();
while (time < 10000){ //for first ten seconds, go east
if(headingValue/10 >= 95 && headingValue/10 <= 270)
Steering.write(left);
if (headingValue/10 <= 85 || headingValue/10 > 270)
Steering.write(right);
if (headingValue/10 >85 && headingValue/10 <95)
Steering.write(straight);
delay(10);
//turn around (west) and keep running home
while(time >= 10000){
if(headingValue/10 >= 275 || headingValue/10 <= 90)
if (headingValue/10 <= 265 && headingValue/10 > 90)
if (headingValue/10 >265 && headingValue/10 <275)
Are you saying it wont read the second batch of directions because it's not specified in the first "while" statement?
I dont know what's going on but It only transmits a compass reading once after startup, which it reacts appropriately to. The problem is it wont update
Gotcha guys, sorry about that. heres the whole picture:
#include <Wire.h>
#include <Servo.h> //includes the servo library to PWM the servo
int HMC6352Address = 0x42;
// This is calculated in the setup() function
int slaveAddress;
int ledPin = 13;
boolean ledState = false;
byte headingData[2];
int i, headingValue;
const int ENA = 9;
const int IN1 = 12;
const int IN2 = 13;
//servo control?
Servo Steering; //defines the servo to be used to steer?
int depthValue;
const int left = 135;
const int right = 45;
const int straight = 90;
// Shift the device's documented slave address (0x42) 1 bit right
// This compensates for how the TWI library only wants the
// 7 most significant bits (with the high bit padded with 0)
slaveAddress = HMC6352Address >> 1; // This results in 0x21 as the address to pass to TWI
Wire.begin();
pinMode(ENA, OUTPUT); // only controls one motor - Hbridge could do 2...
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
Depth.attach(11);
Steering.attach(10); //attaches the steering servo to pin 10
// Send a "A" command to the HMC6352
// This requests the current heading data
Wire.beginTransmission(slaveAddress);
Wire.write("A"); // The "Get Data" command
Wire.endTransmission();
delay(10); // The HMC6352 needs at least a 70us (microsecond) delay
// after this command. Using 10ms just makes it safe
// Read the 2 heading bytes, MSB first
// The resulting 16bit word is the compass heading in 10th's of a degree
// For example: a heading of 1345 would be 134.5 degrees
Wire.requestFrom(slaveAddress, 2); // Request the 2 byte heading (MSB comes first)
i = 0;
while(Wire.available() && i < 2)
headingData[i] = Wire.read();
i++;
headingValue = headingData[0]*256 + headingData[1]; // Put the MSB and LSB together
Serial.print("Current heading: ");
Serial.print(int (headingValue / 10)); // The whole number part of the heading
Serial.print(".");
Serial.print(int (headingValue % 10)); // The fractional part of the heading
Serial.println(" degrees");
delay(10);
//MOTOR CONTROL as taken from somewhere and butchered
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW); // GO!
//my attempts at driving this thing
if (time < 10000){ //for first ten seconds, go east
delay(10);
if(time >= 10000){
delay (10);
I have changed the "while" statements since my original posting for "if" statements and have a faster refresh rate but it still refuses to read the second step - to turn around and go west
I auto-formatted your code - hopefully this makes things clearer.
#include <Wire.h>
int slaveAddress;
int ledPin = 13;
const int ENA = 9;
const int IN1 = 12;
const int IN2 = 13;
//servo control?
int depthValue;
Wire.begin();
Depth.attach(11);
i = 0;
i++;
Serial.print(".");
delay(10);
delay(10);
if(time >= 10000){
delay (10);
So I trimmed a bunch of the extra "delay"s out and it responds quickly to changes in direction but I still cant get it to turn around after 10 seconds... Any suggestions?
an case anyone is looking for this later, heres those last two paragraphs and how I modified them. I really just swapped in "millis() - time" for "time"
if ((millis() - time) < 10000){ //for first ten seconds, go east
if((millis() - time) > 10000){
#include <Wire.h>
int slaveAddress;
int ledPin = 13;
const int ENA = 9;
const int IN1 = 12;
const int IN2 = 13;
//servo control?
int depthValue;
Wire.begin();
i = 0;
i++;
Serial.print(".");
delay(100);
delay (10);
Its just "millis" really which is why I dont understand how this works. I subtract millis from millis and end up with the relative time since start...?
Gaber:
Your initial time (the value from millis() when you initialize time) is going to be nearly 0. All your times are still relative to when the Arduino was restarted, not relative to the last time you did something. If that's what you want, fine, but using now minus just after reset, as opposed to now, didn't really change anything.
Thanks Paul, I understand it now. I thought I had defined "time" as a changing number but now that you say that, I see how it is a fixed number. This is what I want and I see how it works now. I really appreciate the help from all - AWOL, vaj, and Paul.
