Change batteries without powering-off the board
First, I apologize for inadvertently cross-posting my reply to a reply on another forum. In the past I have posted on this forum in the hopes that it will be moved by an administrator to the appropriate forum.
This is my question: I am running a board on battery power. I am using it to collect data. I want to change batteries -but I don't want to interrupt the data input. My board has two, five volt vins. I want to attach the fresh battery without disconnecting the discharged battery (which would power-off the board). Can I have two battery packs attached to the board at the same time? If so, I can then remove the discharged battery pack for recharging, without interrupting the data input. The board's internal power regulator will keep it from overloading, yes?
  • Battery packs can be connected at the same time if you use OR-ing Schottky diodes.
-through just one, 5vin pin, or even the cable port, alone? Looks simple. I build the Schottky diode circuit with two battery terminals and splice a micro USB for connection to the board, that right? Before I try it, is there a video I can look at?
Normally you CAN connect the batteries in parallel temporarily. Without the diodes Larry shows, the dying batteries will drain the fresh batteries but a few (or several) seconds shouldn't hurt much.
My home thermostat loses its programming and day/time when I change the batteries so I bought a battery holder so I can connect temporary batteries while changing. (This means I'll need 2 fresh sets of batteries).
I haven't tried it yet and I'll need to solder some tabs (or something) to make an easier connection with allegator clips.
When I changed the batteries a couple of months ago, I temporarily connected a 10,000uF capacitor to hold the voltage while I quickly changed batteries, and that worked. (IIRC, I charged the capacitor with the fresh batteries first.) But the extra battery solution should work better.
The internal power circuit is intended to protect the board. It is not a feature.
Let me check my concepts; I am aware of three types of transistors: MOSFET, Schottky, and amplifier transistors.
  • The diode you select needs to be able to pass the current expected.
Which board is this?
Is it a custom board?
Guru! Exceptional video. Now, I have to look at Schottky data sheets to pick the right type...
Watching the video, I was reminded of a strange fact. An ordinary magnetic relay in high state is actually alternating high/low. A connected led is blinking, but at a rate too rapid for the eye to notice. It has to do with the frequency of the power supply. True?
Arduino Micro I ordered a few years ago. First time powering the board off the data cable and desktop.
  • Do not understand what you are saying, please reword.
The micro has only one Vin NOT two and it needs a voltage between 7V and 12V
Where do you see two Vins?
I'm reading a pinout diagram. I can't read anything on the board, itself, not even with a magnifying glass. Another reason to build a Schottky adapter for two battery packs...
Input voltage is a sine wave. The Schottky diode "shaves" half the wave, smoothes it, so to speak.
The rapid high/low relay effect can be controlled for applications such as automobile turn signals. Good thing.
The pinout diagram shows TWO Vins?
Maybe this is not an Arduino micro.
Does it look lik this?
  • I am confused, why are you saying Input voltage is a sine wave ?
The video is rubbish. Especially someone with the skill level that needs the explanation will be more confused by it, as is demonstrated here above.
I suspect the 2 Vins are Vin and 5V. Arduino advises against using the 5V pin as input.
