Change clock frecuency (bootloader)
Hello everyone!
I have one Arduino Duemilanove board that works fine. This board has an ATMEGA328 that works at 16MHz and 5V. I want to design a new board based on Arduino philosophy that will works at 3.3V. For this operation voltage I must to down clock frecuency. I want that this new board has a bootloader like Arduino Duemilanove so I will can program directly from Arduino IDE. Since original Arduino Duemilanove boards has a 16MHz I can not use the same bootloader for my board. My question is how can I compile a bootloader with a different clock frecuency? If I change clock frecuency in bootloader source code and then I compile it, does it works?
Thanks in advance.
Regards.
PD: Sorry for my horrible english
Hello.
arlukas: My question is how can I compile a bootloader with a different clock frecuency?
Instead of compiling the bootloader you may be able to use an existing one...
ATmegaBOOT_168_atmega328_pro_8MHz.hex ATmegaBOOT_168_pro_8MHz.hex LilyPadBOOT_168.hex
Select the Arduino that most closely matches your board and use its bootloader.
Or, westfw may be willing to give you a copy of an 8 MHz version of Optiboot for your board.
Dear Coding Badly,
Thanks for your reply and advice. Few hours ago I finded something similar. The idea to compile a new bootloader with different clock frecuency is that I only have 4MHz clock. If I donĀ“t obtain the way to compile a specific bootloader I will try to adquire 8MHz clock. Thanks anyway.
Anyone can help me?
Thanks in advance.
Regards to all.
You don't need to get a 8mhz clock. It's internal to the chip.
