I have the following code working but it only works on a singular one off basis, i want it to cycle through every 5 seconds, any help much appreciated.
def recvFromArduino():
global startMarker, endMarker
ck = ""
x = "z" # any value that is not an end- or startMarker
byteCount = -1 # to allow for the fact that the last increment will be one too many
# wait for the start character
while ord(x) != startMarker:
x = ser.read()
# save data until the end marker is found
while ord(x) != endMarker:
if ord(x) != startMarker:
ck = ck + x.decode("utf-8") # change for Python3
byteCount += 1
x = ser.read()
return(ck)
def waitForArduino():
# wait until the Arduino sends 'Ok' - allows time for Arduino reset
# it also ensures that any bytes left over from a previous message are discarded
msg = ""
while msg.find("Arduino is ready") == -1:
while ser.inWaiting() == 0:
pass
msg = recvFromArduino()
print (msg) # python3 requires parenthesis
print ()
import serial
import time
print ()
print ()
# NOTE the user must ensure that the serial port and baudrate are correct
# serPort = "/dev/ttyS80"
serPort = "/dev/ttyUSB0"
baudRate = 9600
ser = serial.Serial(serPort, baudRate)
print ("Serial port " + serPort + " opened Baudrate " + str(baudRate))
startMarker = 60
endMarker = 62
file = open('/home/pi/Desktop/SerPython/read_it.txt')
waitForArduino()
waitingForReply = False
while 1:
line = file.readline()
if not line:
break
if waitingForReply == False:
waitingForReply = True
ser.write(str.encode(line))
print ("reading file and writing line to arduino " + line)
if waitingForReply == True:
print ("waiting for reply")
pass
dataRecvd = recvFromArduino()
print ("Reply Received " + dataRecvd)
print ("===========")
time.sleep(5)
file.close
print ('file closed')
print
ser.close
print ('serial closed')
