Change data from int to char. Data sending with Adafruit Feather 32u4
Hello friends,
I want to send the value of some variables (P, T) by radio with my Feather 32u4 module. I obtain these values with a BMP180 pressure and temperature sensor:
//Program of BMP180 to get pressure and temperature:
char status;
double T,P;
status = bmp180.startTemperature();//Inicio de lectura de temperatura
if (status != 0)
delay(status); //Pausa para que finalice la lectura
status = bmp180.getTemperature(T); //Obtener la temperatura
if (status != 0)
status = bmp180.startPressure(3); //Inicio lectura de presión
if (status != 0)
delay(status);//Pausa para que finalice la lectura
status = bmp180.getPressure(P,T); //Obtenemos la presión
if (status != 0)
Serial.print("Temperatura: ");
Serial.print(T,2);
Serial.print(" *C , ");
Serial.print("Presion: ");
Serial.print(P,2);
Serial.println(" mb");
Then, I want to send these 2 variables via radio with mi Feather 32u4 but I do not know how to do it:
//Program of the Rfm69 (Adafruit 32u4) module to send a text:
char radiopacket[20] = "Hello World #";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending "); Serial.println(radiopacket);
// Send a message!
rf69.send((uint8_t *)radiopacket, strlen(radiopacket));
rf69.waitPacketSent();
I know how to send a plane text, but I can't send the variables. Could you please help me??
Thank you very much,
The simplest, but by no means best, is to use sprintf(). Mr. Google is waiting...
PaulS:
bearing in mind that floats are not implemented in Arduino for sprintf() and consider using its safer cousin, snprintf().
char radiopacket[32];
snprintf(radiopacket, sizeof(radiopacket), "T:%d.%dH:%d.%d", int(T), int(T * 10) % 10, int(P), int(TP* 10) % 10);
// Send a message!
Well, there is dtostrf() to convert one float/double to one string.
