Hi all,
Sorry to still be super-noob at programming after years of tinkering, but...can anyone tell me why this code doesn't work?
//Camera Motor sketch for use with LadyAda motor shield and DC motor
//and 2 digital ins which tell motor when to change directions
//Because the analogue pins are available on the motor shield, I am using
//A4 and A5 as digital ins.
#include <AFMotor.h>
int botBut = A5;//pin that receives input from the bottom button
int topBut = A4;//pin that receives input from the top button
int valTop = LOW;//intitalizing top button
int valBot = LOW;//initializing bottom button
int minStep = 200;//least # of steps per 'go'
int maxStep = 500;//maximum # of steps per 'go'
int stepNum = 100;
AF_DCMotor motorD(2, MOTOR12_64KHZ);//DC motor on motor port 2 at 64 khz
pinMode(botBut, INPUT);//button to tell motor it is at the end of its run on one side
pinMode(topBut, INPUT);//button to tell motor it is at the end of its run on one side
motorD.setSpeed(100); //set the speed of the motor
valTop = digitalRead(topBut);//check the state of the top button
valBot = digitalRead(botBut);//check the state of the bottom button
if (valTop == LOW && valBot ==LOW){//If neither button is pressed,
Serial.println("LOW,LOW");
Direction();
else if (valTop == HIGH) {
for(int i=0;i<20; i++){ //this is long enough to disengage the button
motorD.run(BACKWARD);
Serial.println("BACKWARD, TOPHIGH");
else if (valBot == HIGH){
motorD.run(FORWARD);
Serial.println("FORWARD, BOTHIGH");
void Direction(){
boolean FB = (int) random (0,2);
if (FB == true) {
GoForward ();
if (FB == false) {
GoBackward ();
}//step the motor as presecribed byt he "go" funciton
void GoForward(){
stepNum = (int)random(minStep, maxStep);
for (int i = 0; i< stepNum; i ++){
Serial.println ("FORWARD!");
if(valTop==HIGH){
for (int i=0; i<200; i++){
if(valBot==HIGH){
void GoBackward(){
Serial.println ("BACKWARD!");
if(valTop==HIGH){
for (int i=0; i<20; i++){
//lastvalTop = valTop;
if(valBot==HIGH){
I have external resistors. I've got the code working now. The problem seems to have been the logic of the GoForward and GoBackward functions. The motor just jerked around when the buttons were pushed. Thanks for putting your eyeballs on the last version. I'm sure this one is not too elegant, but it's doing what I want for now. Suggestions for improvement most welcome.
HH
int minStep = 300;//least # of steps per 'go'
int maxStep = 700;//maximum # of steps per 'go'
int stepNum = 400;
Direction();
for(int i=0;i<200; i++){ //this is long enough to disengage the button
void Direction(){
int FB = random (0,2);
if (FB == 0) {
GoForward ();
if (FB == 1) {
GoBackward ();
void GoForward(){
Serial.println(stepNum);
if(valTop==HIGH){
Serial.println("GFTopHigh");
else if(valBot==HIGH){
Serial.println("GFBotHigh");
else if(valBot==LOW && valTop==LOW){
void GoBackward(){
if(valTop==HIGH){
Serial.println("GBTopHigh");
Serial.println("GBBotHigh");
