Change FileName And Count NameIndex
Hello together,
i´d like to Change Filename by pressing a button:
Messer00.csv
Logger00.csv etc…
and i want to Count the index up if the file is already exisiting
Messer00 - Messer01.csv etc
// create a new file
char filename = “LOGGER00.CSV”;
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + ‘0’;
filename[7] = i%10 + ‘0’;
if (! SD.exists(filename)) {
// only open a new file if it doesn’t exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
so, what to do - please
thanks
DonClemente
That snippet of code seems to do what you want. What is the problem?
i come from vb.net and i´m new on c
so i try again
in
i want to replace
“LOGGER00.CSV” by some Kind of variable; lets call it FN
so it Looks something like
char filename = FN;
when pressing button 1 the FN changes
FN = Messer00.csv
FN = Logger00.csv
when pressing button 2 the saving begins…
char filename = FN;
so, how to declare FN ?
Thanks DC
Create a new function, pass the function the address of the array you want to use as the file name.
thanks for your help,
but as im new on C could i please have some code...
Read this to learn about functions:
https://www.arduino.cc/en/Reference/FunctionDeclaration
Create a function in which you pass a byte parameter, let’s call it ‘whichFile’.
When ‘whichFile’ is == 0, use Messer00.csv as the base for your file name.
When ‘whichFile’ is == 1, use Logger00.csv as the base for your file name.
Edit:
//create a new file and open for write
//return true if successful, else false
bool openFile(byte whichFile)
  if (whichFile != 0 && whichFile != 1)
    return false;
  char filename1[] = "Messer00.csv"; //whichFile == 0  default
  char filename2[] = "Logger00.csv"; //whichFile == 1
  char *p = filename1;
  if (whichFile == 1)
    p = filename2;
    p[6] = i / 10 + '0'; //  or     *(p + 6) = i / 10 + '0';
    p[7] = i % 10 + '0'; //  or     *(p + 7) = i % 10 + '0';
    if ( logFile.open( p, O_CREAT | O_EXCL | O_WRITE ) )
  return logFile.isOpen();
} //E N D  o f   o p e n F i l e ( )
