Change Font with Adafruit on PCD8544-Nokia 5110 LCD ??
How I can change Font with Adafruit on PCD8544-Nokia 5110 LCD ??
cross posted here. Do not cross post. Cross posting wastes time. Have the moderator merge the post in the link with this one. This is the better place for your question.
It is appropriate to ask a Font question in "Displays" Forum.
Just ask a Moderator to move your message. (best)
Or explain your move to a new Forum and add links both ways. i.e. old thread to your new message and the new thread to your original. So readers will know.
Yes, most Adafruit libraries inherit from Adafruit_GFX.
This means that you can use FreeFonts as well as the basic 5x7 font.
Update your Adafruit_PCD8544 and Adafruit_GFX via IDE Library Manager.
Then try the packaged FreeFonts. Or import a foreign font into FreeFont format via an online website.
David.
unfortunately I was not able to change the font, does anyone know a little more precisely if it is possible to change the font in each row a different font ...??
I solved the problem
#include <Fonts/FreeSerifBold12pt7b.h>
display.setFont(&FreeSerifBold12pt7b);
display.setFont(); //default font
You can edit the library.
You can dispense with the library and make your own font.
You can modify the standard font with glyphs
http://carlos-rodrigues.com/pcd8544/
