system
#1
I want to change the I2C-address of a srf08 ultrasonic sensor with an arduino UNO.
I shifted the Codes but it does not work:
#include <Wire.h>
#define Old_Address 0x70
#define New_Address 0x72
Wire.begin();
delay(100);
Wire.beginTransmission(Old_Address);
Wire.write(0);
//Wire.write(0xA0);
Wire.write(0x50);
Wire.endTransmission();
delay(60);
Wire.write(0);
//Wire.write(0xAA);
Wire.write(0x55);
delay(60);
Wire.write(0);
//Wire.write(0xA5);
Wire.write(0x52);
delay(60);
Wire.write(0);
Wire.write(New_Address);
delay(60);
void loop(){
pylon
#2
You have to send it in one sequence, not 4 and use the correct values as the datasheet describes:
#include <Wire.h>
#define New_Address 0xF2
Wire.begin();
delay(100);
Wire.write(0);
//Wire.write(0xA0);
Wire.write(0x50);
delay(60);
Wire.write(0xA0);
Wire.write(0xAA);
Wire.write(0xA5);
void loop(){
After that you have to use the new address, which will be 0x79 (8bit 0xF2 shifted to the right one bit).
system
#3
It is still not working.
#include <Wire.h>
Wire.begin();
delay(100);
Wire.write(0xA0);
delay(50);
Wire.write(0xAA);
delay(50);
Wire.write(0xA5);
delay(50);
void loop(){
system
#4
Ok. I have it. Thank you for your help!
#include <Wire.h>
#define oldad 0x70
#define newad 0xE4
Wire.begin();
delay(100);
Wire.beginTransmission(oldad);
Wire.write(0x00);
Wire.write(0xA0);
delay(60);
Wire.write(0x00);
Wire.write(0xAA);
delay(60);
Wire.write(0x00);
Wire.write(0xA5);
delay(60);
Wire.write(0x00);
Wire.write(newad);
void loop(){
