Hello
Is it possible to change the appearance of the web server in the wifi manager library? For example, I want the info and update options to be deleted.
You have the source code for the library so why not have a go at changing it yourself ?
Make a copy of the original before you change anything
std::vector<const char*> wmMenuItems = { "wifi", "exit" };
wm.setMenu(wmMenuItems);
I don't know how to access the library code and open it.
Can I open the source code in Arduino and change it?
thank you Juraj . How to open the source code in the Arduino ?
at the top of your code you have a line
#include < filename.h >
search for this filename on your harddisc
A library contains a *.h and a *.cpp-file
As a minimum you should provide your source-code so that anyone can see what library you are using
best regards Stefan
the code snippet goes into setup() of your sketch
Yes, I did it. Thank you very much guys.
