Hey all, I have working code to light up my WS2812B with a potentiometer - but can't find any good tutorials or examples to switch input from a potentiometer to an ultrasonic sensor.
trying to get it to light up more as object gets closer to the prox sensor
any help in the change is greatly appreciated. Thanks - Jane
#include "FastLED.h"
#define LED_TYPE WS2811
#define PIN_SLIDE_POT_A A0 // input pin of the slide pot
#define MAX_SLIDE_POT_ANALGOG_READ_VALUE 1020 // maximum voltage as analog-to-digital converted value, depends on the voltage level of the VCC pin. Examples: 5V = 1023; 3.3V ~700
#define NUM_LEDS 55 // add number of LEDs of your RGB LED strip
#define PIN_LED 3 // digital output PIN that is connected to DIN of the RGB LED strip
#define LED_COLOR CRGB::White // see https://github.com/FastLED/FastLED/wiki/Pixel-reference for a full list, e.g. CRGB::AliceBlue, CRGB::Amethyst, CRGB::AntiqueWhite...
CRGB grb_led[NUM_LEDS]; // color array of the LED RGB strip
#define COLOR_ORDER GRB
const int buzzer=11;
pinMode(PIN_SLIDE_POT_A, INPUT);
FastLED.addLeds<WS2812B, PIN_LED>(grb_led, NUM_LEDS);
FastLED.addLeds<WS2812B, PIN_LED, GRB>(grb_led, NUM_LEDS);
//FastLED.addLeds<WS2812B, PIN_LED, GRB>(leds, NUM_LEDS); // GRB ordering is typical
FastLED.setBrightness(15);
Serial.println("Setup done.");
pinMode(buzzer, OUTPUT);
// 1) Analog value of slide pot is read
int value_slide_pot_a = analogRead(PIN_SLIDE_POT_A);
Serial.print("Slide Pot value: ");
Serial.println(value_slide_pot_a);
// 2) Analog value is mapped from slide pot range (analog input value) to led range (number of LEDs)
int num_leds_switchedon = map(value_slide_pot_a, 0, MAX_SLIDE_POT_ANALGOG_READ_VALUE, 0, NUM_LEDS);
// 3) Light up the LEDs
// Only LEDs are switched on which correspond to the area left of the slide knob
for (int i = 0; i < num_leds_switchedon; ++i) {
grb_led[i] = LED_COLOR;
// LEDs are switched off which correspond to the area right of the slide knob
for (int i = num_leds_switchedon; i < NUM_LEDS; ++i) {
grb_led[i] = CRGB::Black;
for (int i = 0; i < num_leds_switchedon; ++i) { if (value_slide_pot_a > 785) {
grb_led[i] = CRGB::DarkRed;
FastLED.setBrightness(45);
tone(buzzer, 110);
//digitalWrite(buzzer, HIGH);
} else if (value_slide_pot_a > 450) {
grb_led[i] = CRGB::DarkGreen;
noTone(buzzer);
//digitalWrite(buzzer, LOW);
} else if (value_slide_pot_a > 120) {
grb_led[i] = CRGB::DarkGray;
FastLED.show();
