CHANGE interrupt on any pin?
Can any of the UNO's pins be used as a CHANGE interrupt? I thought I have heard so, but the Arduino reference doesn't make note of this.
There are two interrupt pins on the UNO.
Pin D2 and pin D3.
These are interrupts 0 and 1.
You can assign rising, falling, change, and low.
Mr. Gammon has a great discussion here:
Any of the Uno's twenty or so I/O pins can be used as a change interrupt.
Read the gammon web page.
There seems to be conflicting information. How would I attach an CHANGE interrupt to pin 8, for example (if possible).
See the Arduino Pin Change Interrupt page
Not sure what "reference" you looked at. From the Arduino Uno page:
External Interrupts: 2 and 3. These pins can be configured to trigger an interrupt on a low value, a rising or falling edge, or a change in value. See the attachInterrupt() function for details.
Regards,
Ray L.
Only the DUE can use interrupt on almost any pin.
See my link. You can use a change interrupt on almost every pin of an Uno. There are only just 3 different interrupt routines for them. So in the routine it's up to you to check which pin caused the trigger/changed.
And for a lot of things this is fast and efficient enough.
