change IR sending data frequency
Dear all,
how to change library's "IRremote" sending frequency from 38khz to 56khz ?
my sensor "TSOP4856" worked with 38khz but i guess it would perform better on 56khz .
What library are you using? Link please?
void  IRsend::enableIROut (int khz)
the TSOP4856 datasheet says it operates at 56 kHz
aarg:
IRremote Library
johnwasser:
where to use it
gcjr:
yes i know ... but oddly it worked fine
Anybody please :slight_smile:
adolfhack:
Did you not read reply #2?
johnwasser:
thank you john .. i read it and asked where to use this line ?
adolfhack:
You have a call to .enableIRIn() in setup(), right? Put the value in kHz as an argument to that call. Since you didn't post your sketch I can't be more specific.
