Change keyboard settings in arduino
Hi guys. I just wrote a code that theoretically can translate a joysticks 16 directions into wasd (see code below). My problem is that by default, keyboards only input one character at a time (i.e. ewwwwwwwwwwwwwww or waaaaaaaaaaa). Is there any way to get around this? Any help would be appreciated!!!
Note: I am using an arduino uno (can get a mega if necessary) and a motor shield with power supply. I am also using a logitech extreme 3d pro joystick
_16DirWASDControl.ino (7.8 KB)
Keyboards don't IMPORT anything. Keyboards are OUTPUT devices.
Applications import data.
void shuffle(char ara []) {
  char ins = Serial.read();
  Serial.flush();
Block until all outgoing serial data has been sent. How the hell is that useful?
I just removed that from my code but still that doesn't solve my problem. I am wondering what code I can implement that will remove the delay time of key presses (to 0 ideally) and that will allow me to input multiple keys such that the joystick outputs something allows the other 12 non cardinal directions to operate.
I still don’t understand the question. What are you inputting the keys to? Supposedly, you are reading the joystick values and calculating some value to output. There should only be a value output if the joystick readings have changed.
When the joystick is on a diagonal, you'll have to send wawawawawa or sdsdsdsdsd or even wwawwawwawwa.
Your code will have to deal with all 16 possibilities.
PaulS: I will try to clarify my question. I am trying to convert a joystick movement into wasd movement such that you can also move in diagonals. My joystick (logitech extreme 3d pro), has 3 programmable axes, two of which are the standard x and y. I am trying to convert my motion on x and y to key strokes. As of now, I have:
right:d, left:a, up:w, down:s (standard wasd control seen in many games, programs, etc). However, if I move diagonally on the joystick, the motion is converted to just one letter instead of a mix. As Delta_G suggested, I should try to output wdwdwdwdwdwd if pointed in a diagonal, however, keyboards do not do this by default. As I noted earlier, typically keyboard output someting like wddddddddddddd if you try to hit two keys at once. I am asking if there is any way to write code such that the input would instead read wdwdwdwdwdwdwdwdwd if I pointed my joystick up and right.
Delta_G: I wish that there were 16 buttons or slots I could map to my joystick but unfortunately this is not the case. Currently, it has 3 programmable axes, only two of which correlate with x and y movement. For the x axis, I have a and d set for the extremes and for the y axis, I have w and s set for the extremes. I havent been able to find a software that can map my joystick with diagonals settings so I am stuck trying to manipulate key presses.
Thanks for the replies!
So how does the joystick know it’s being moved to a diagonal? Your program is going to have to think a little harder. If both the up and right directions are engaged then it is on a diagonal. So in that case send keystrokes to move diagonal.
In my code, I have a char array which collects no more than 4 characters. The number of w,a,s or d’s is counted by method countDirec. In each while loop, see code I attached, the direction is determined by the number of each variable, which allows me to get directions such as NNW, NW, or WNW. I tested this in the serial monitor and found that the arduino was able to determine which direction based on keyboard input but I had to manually type in keystrokes such as wawawa in order to yield these results. My challenge is now finding out how the joy stick can output wawawa.
Because no solution was found, I will just share what I know:
A keyboard listener could potentially be used (keyboard class in arduino) however, it only works for the Leonardo board I believe. In my case, I am using an uno so this capability is missing. Without this, I am at the mercy of the joystick software which sadly does not let me code the diagonals. It seems that mapping to a keyboard is hopeless so the next best solution is to download a usb shield that could read data directly from the joystick or try your hand at inbetwino.
