Change LED brightness during stepper motor loop
Hi there, I am using an ultrasonic sensor to monitor distance. When something gets close enough I trigger a stepper motor to run. At the same time I want a neopixels LED strip to get brighter.
Here is the code I use to run the stepper. I am turning some 26 revolutions Question is can I do the step.setBrightness() inside the for loop without changing the stepper behavior? Would there be a better way to increase the LED brightness over this same interval?
 for(int i = 0; i < 5313; i++)
    digitalWrite(5, HIGH);
    delayMicroseconds(500);
    digitalWrite(5, LOW);
    strip.setBrightness(.047 * i);
Yes. Let the loop() function do the looping for you and use the BWoD principle for timing to prevent blocking execution of other code.
See Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
leds.setBrightness( Brightness ); //  1 = min brightness (off), 255 = just below max brightness.
The issue with the Adafruit_NeoPixel setBrightness is that the brightness can be decreased but not increased. On the Adafruit discussion forum is a conversation about how to modify the cpp to have the setBrightness command increase and decrease brightness without a rest of the uController.
Thanks guys! The BWoD example was just what I needed. Instead of setBrightness() I just used strip.fill with a 0-255 color instead which seems to work well.
This leads to another question though - if I strip.fill() with just red at 0-255 and use 0 for green and blue like so:
strip.fill(strip.Color(rColor, 0, 0), 0, LED_COUNT - 1);
    strip.show();
The stepper turns noticeably rougher and slower. If I just change the fill to make purple, or white, like so, then the motor is very smooth.
strip.fill(strip.Color(rColor, 0, rColor), 0, LED_COUNT - 1);
strip.show();
Does this make any sense to anyone?
