Change MIDI CC hexidecimal/bit using CCButtons
Hey!
Been using the Control Surface library by Pieter P and wondered if there was any way to specifically select the hex/bit using the CCButton function?
For example this:
20 | 14h | Voice 1/2/3 Waveform | 0-15: val |
| | Bit 0: Triangle | |
| | Bit 1: Saw | |
| | Bit 2: Pulse | |
| | Bit 3: Noise (disables all other waveforms)| |
| | Bit 4: Disable Voice | |
| | Bit 5: Sync | |
| | Bit 6: Ringmodulator | |
| | Example: 02h = 2 = Saw | |
| | Example: 05h = 5 = Triangle & Pulse | |
| | Example: 21h = 33 = Triangle & Sync | |
Is there a way of selecting the bit for the CCButton?
here's my code for the button section using CD74HC4067 mux
////////switches/buttons//////////
// Instantiate an analog multiplexer 2
CD74HC4067 mux2 = {
  2,       // Analog input pin
  {3, 4, 5} // Address pins S0, S1, S2
CCButton Buttons[] = {
  { mux.pin(0), { 20, CHANNEL_1 } },///Triangle
  { mux.pin(1), { 20, CHANNEL_1 } },///Saw
  { mux.pin(2), { 20, CHANNEL_1 } },///Pulse
  { mux.pin(3), { 20, CHANNEL_1 } },////Noise
  { mux.pin(4), { 20, CHANNEL_1 } },////Sync
  { mux.pin(5), { 20, CHANNEL_1 } },///Ring Mod
  { mux.pin(6), { 8, CHANNEL_1 } },///Filter 1 on
  { mux.pin(7), { 8, CHANNEL_1 } },////Filter 2 on
  { mux.pin(8), { 8, CHANNEL_1 } },////Filter 3 on
  { mux.pin(9), { 8, CHANNEL_1 } },///Filter Audio in on
  { mux.pin(10), { 9, CHANNEL_1 } },///Low pass
  { mux.pin(11), { 9, CHANNEL_1 } },///Bandpass
  { mux.pin(12), { 9, CHANNEL_1 } },////Highpass
  { mux.pin(13), { 64, CHANNEL_1 } },////Sustain
Think I've figured it out :wink:
You can add another bracket underneath each with the values for on and off
{1,127} ////value on/off
