I am using this example of a arduino modbus slave, it works fine.
I want to be able to change the slave id from my program (the user will do it from a display and buttons), but how can I program this change since the object slave is declared outside setup() and loop()?
If I put the line "Modbus slave(2,0,TXEN);" inside setup(), it has "setup" as scope, and loop() will not see it.
* Modbus slave example 3:
* The purpose of this example is to link a data array
* from the Arduino to an external device through RS485.
* Recommended Modbus Master: QModbus
* http://qmodbus.sourceforge.net/
#include <ModbusRtu.h>
// assign the Arduino pin that must be connected to RE-DE RS485 transceiver
#define TXEN 7
// data array for modbus network sharing
uint16_t au16data[16] = {
3, 1415, 9265, 4, 2, 7182, 28182, 8, 0, 0, 0, 0, 0, 0, 1, -1 };
* Modbus object declaration
* u8id : node id = 0 for master, = 1..247 for slave
* u8serno : serial port (use 0 for Serial)
* u8txenpin : 0 for RS-232 and USB-FTDI
* or any pin number > 1 for RS-485
Modbus slave(2,0,TXEN); // this is slave @2 and RS-485
slave.begin( 19200 ); // baud-rate at 19200
slave.poll( au16data, 16 );
